version ok is 6.0.2900.2180
the sollution of UNAR is ok
Solution is very easy.
If You have problem with checksum when R/W only flash, Your OS dont have C++ library. Two way:
- download C++ libarary from net -> instal it
or
- download from alientech website ksiute 1.85 -> install it, it will install C++ automatically -> remove dir C:\KSiute -> Replace it with KSiute dir which You get from Your clone supplier -> restart WIN -> be happy with Your master ktag.
Solution tested and works on 3 computers.
DONT START KSIUTE WITH YOUR CLONE BEFORE YOU REPLACE KSIUTE DIRECTORY!!!
I think it is helpful and make less stress for ktag clone users.
If I help You make thanks
BR
unar
busaman (28th September, 2014), devil85 (13th October, 2023), eduardo131 (17th October, 2016), YASS59 (11th May, 2020)
for all
ksiute 1.85 with install C++
antwnhszr (20th June, 2017), devil85 (13th October, 2023), eduardo131 (17th October, 2016), el genio (30th October, 2022), electronicdeivi (16th February, 2022), Hayssam1 (1st May, 2022), jkubp (8th May, 2023), laurentiudania (11th August, 2022), ljamert (13th October, 2023), shanektm450 (23rd October, 2019), tellfaia (28th October, 2021), yapm (8th November, 2016), YASS59 (11th May, 2020), youngcat (1st February, 2021)
KESS V2 2.06 fix up checksum error.
i have some problem with KESS V2. When R/W file to ECU i get checksum error. C++ library is installed by Ksuite 1.85 and doesn't work.
Firmware from KESS V2 is 4.036. Which is actually the best working ksuite with clone?
i have the same problem 2.28 fw 4.036
i have unlock an pcr2.1 and this work.
when i read it came Checksum error
win xp and c++ 2005 2008 and 2010 installed same problem
what can i do?
install old version of ksuite , and new version after
work it for me ( after intall c++ 2005;2008;2010 )
I have kess v2 4.036 and when try to read mercedes benz w210 200cdi euro3 i get chekcsum error and ksuite crashes. Tried install c++ 2005/2008/2010 with no luck. Ksuite is 2.23. Any ideas where to look for problem?
try and find 2.08 stable and made for that f/w
I have same problem, but i can read and cant write
