Anyone got it im lookin to or any version that lets you do 5 cylinder cutouts.
Supposedly, not for sure yet, but 05 will do what your lookin to do. Dunno but if your trying to balance injectors maybe you know what codes will do what to a injector?
When you first go into the cutout test screen, BEFORE you click "Start" you will see Cyl 1,2,3,4,5,6 and "Powered" under the "Mode" heading to the right of each cylinder.
Highlight the cylinder you want to cut out, and click the "Change" button at the bottom. That cylinder will cut out, and you can continue to select cylinders to cut out until you have 5 cylinders cut out. Click "Change" again to power the highlighted cylinder again. Clicking "Power All" will repower any cut out cylinders.
The fuel position is displayed on the right side of the screen, so you can note the fuel position required to maintain RPM while running on each individual cylinder.
by double clicking on the injector under "cylinder cutout test" you will manual cutout the cylinder.
can you cut out all 5 this way?
I know it leaves numbers but you need trim files with different flow rates to balance engine.
