axl123456789 (27th December, 2014)
Welcome to DK.
I don't see much wrong with your sysCheck only Full cios wad pack is missing wads 202, 222, 223 and 224.
Well the second picture you've shown USB device not found switching to channel list mode. Means it can't find the HDD plugged in. That normally means its formatted wrong, its an incopmpatible HDD or you've added the games onto the drive incorrectly.
Now you've made you first post you should be able to download files in that section.
Keith
2010 Golf GTD (170)
Keithuk help me. Please.
When I play the original game disc from the disc channel on the Wii menu, I get the error message like this:
But I play the disc through USBLoaderGX, it goes well. Do you have any good idea??
I never got that kind of the message with the same game disk before I softmode my Wii.
I've heard of this wii error #002 talked about if you Google it. Do you know something I've missed a few wads of your sysCheck that I've only just seen 202, 222, 223 and 224. Like I said to dlhilario yesterday.
I was probably looking at the total stub count. Try these wads first. That won't make the total stub count to 0.
In USB Loader GX settings there is an option to turn the Error 002 Fix you can turn ON/OFF make sure its ON. There are loads of video's on YouTube about this error.
Keith
2010 Golf GTD (170)
You misunderstand. I have trouble only when I play directly from the disc with the Wii's disc channel on Wii System Menu
I understood what you said you only get this error when you play original game disc from the disc channel. The games on the HDD play ok. Have you installed the missing wads I said you needed?
Is the USB Loader GX settings option to turn the Error 002 Fix turned ON?
Keith
2010 Golf GTD (170)
Yes, Keithuk
I did everything you said. But it is not better.
Well I don't know what to say if you've installed 202, 222, 223 and 224 wads your sysCheck is going to the the same as mine and my system doesn't show that error if I play a genuine disc.
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Priiloader installed
Drive date: 2008.07.14
Homebrew Channel 1.1.0 running on IOS58
HomebrewFilter ist nicht installiert
Homebrew Filter is not installed
Hollywood v0x11
Console ID: 91742115
Boot2 v4
Found 134 titles.
Found 55 IOS on this console. 4 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2013/01/08.
Keep Googling for this error.
Keith
2010 Golf GTD (170)
OK, I try to reinstall 202, 222, 223 and 224 wads to see what happens....
Hey guys I got the same problem and going to try this solution!
Thanks!
Tried the solution and installing all those wads worked. Thanks!
Welcome to DK.
I'm glad it worked for you Muasau hasn't been back to say if his works now or not.
Keith
2010 Golf GTD (170)
will try asap and get back to report
Keithuk, all your responses are exactly what I was looking for. Thank you very much.
