USBLoaderGX "Exception (DSI) occurred" - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    Sep 2014
    Hi Keithuk! i have the same problem with the hdd , my wii cant recognize it, i tried all of the things that you said but the problem continues, can i send to you my syscheck?? sorry for my english im portuguese :P thnks
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x11
    Console ID: 77099321
    Boot2 v4
    Found 79 titles.
    Found 54 IOS on this console. 4 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, USB 2.0
    IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, USB 2.0
    IOS224[57] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/09/08.
    Last edited by sfns; 8th September, 2014 at 01:08 AM. Reason: adi?ao de mais informa?ao
  2. #47
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    I don't see much wrong with that old sysCheck only you have d2x-v7final install. Download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads.
    That's an old sysCheck v2.1.0b11 try sysCheck19
    As this drive ever work and is it compatible?
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    sfns (8th September, 2014)
  4. #48
    Sep 2014
    it never worked, normaly i play on a usb drive ( pen) and it works , i dont know if its compatible its a iomega mmhdu with 500 gb , i format it in fat 32 and i put the games in wbfs . ok i will try to install what you said thanks , i can send to you a new check with the newer version.
  5. #49
    Sep 2014
    here is my new system check :
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    Region: PAL
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Boot2 v4
    Found 79 titles.
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10
  6. #50
    Aug 2010
    England
    Your iomega mmhdu 500 GB dive may not be compatible USB Compatibility List
    Have you tried WBFS Manager?.
    You sysCheck is the same as mine apart from IOS16, if you want to install my cIOS16-v257
    My sysCheck #MKWDueNa
    iomega minimax drive detected as hub by usb loaders - GAF's Wii Homebrew Tutorial
    Keith
    2010 Golf GTD (170)
  7. The Following User Says Thank You to Keithuk For This Useful Post:
    sfns (9th September, 2014)
  8. #51
    Sep 2014
    yes i use wbfs manager always since i?ve been hacking the wii , and it works fine for the pen drive and not for the hdd, so i thought that it may not be compatible . I will try to install yours. Maybe i need to buy another brand of hdd, thanks anyway ;D
  9. #52
    Dec 2014
    Just wanted to quickly say thanks for your help I was really stuck until reading this thread and following your instructions!
  10. #53
    Jan 2015
    Hi guys!
    I 'm new to the wii stuff, cause it's a friend's of mine. I tried to load games from the External drive.
    My error looks the same. I've copied the my syscheck below, as well.
    SysCheck v2.3.0 HacksDen Edition by JoostinOnline, Double_A, R2-D2199, and Nano
    Region: PAL
    Drive date: 02.13.200702
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID:
    Console Type: Wii
    Shop Channel Country: Greece (79)
    Boot2 v4
    Found 113 titles.
    Found 51 IOS on this console. 8 of them are stub.
    IOS9 (rev 54321): Trucha Bug
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 269): No Patches
    IOS13 (rev 273): No Patches
    IOS14 (rev 520): No Patches
    IOS15 (rev 523): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 775): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 782): No Patches
    IOS22 (rev 1037): No Patches
    IOS28 (rev 1550): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS33 (rev 3091): No Patches
    IOS34 (rev 3348): No Patches
    IOS35 (rev 3349): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 3869): No Patches
    IOS38 (rev 3867): No Patches
    IOS40 (rev 3072): Stub
    IOS50 (rev 54321): Trucha Bug
    IOS52 (rev 5888): Stub
    IOS53 (rev 5406): No Patches
    IOS55 (rev 5406): No Patches
    IOS57 (rev 5661): No Patches
    IOS60 (rev 54321): Trucha Bug
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS224[37] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS247 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS248 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS249 (rev 65280): Stub
    IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10
    Report generated on 01/04/2015.
    Thanks in advance!
  11. #54
    Aug 2010
    England
    You have IOS's that are Stub the main ones being IOS249 which are used for external drives. You do have IOS36 and IOS236 that's all but you need to reduce that 9 down to 4 or 5.
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    You have 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
    Keith
    2010 Golf GTD (170)
  12. The Following User Says Thank You to Keithuk For This Useful Post:
    StasisPm (6th January, 2015)
  13. #55
    Jan 2015
    Thanks a lot for your response Keithuk.
    Tomorrow, that I'll have some free time, I'll check it out and come back with the new syscheck.
  14. #56
    Jan 2015
    Ok. So, I copied the "d2x wad pack" in the COPY_TO_SD wad folder, replacing the 2 d2x v8 wads. And then, all those files and folders to the SD. Now, these, are ready to be installed through the WAD Manager, right?
    But first, you suggested reinstalling the IOS236.
    Quote Originally Posted by Keithuk View Post
    The problem is that there's no " IOS236 Installer v5 Mod" in the Hombrew.
    So, I downloaded it from here, extracted the zip at the SD root (as written in the downlad page's info) and put the SD back to wii.
    The Installer did not appear either!
    That's the point I'm stuck, right now.
  15. #57
    Aug 2010
    England
    The files in IOSvMod.zip are the same that are in other app COPY_TO_SD
    Post a new sysCheck so I can see what's changed?
    Keith
    2010 Golf GTD (170)
  16. #58
    Jan 2015
    The new sysCheck is exactly the same.. Nothing has changed. And I think that's normal, cause all I've done up to now as I said, is downloading from Windows and moving wads and files to SD. Which was the below part of your instructions
    1. "Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card.
    That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card."
    Next step now, as you said (and where I'm stuck)..
    2. "Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads.
    If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all."
    So.. What I've understand is that I have to install the wads I've moved in the SD in the 1st step, using the Multi-Mod Manager, under the Homebrew Channel (I do see this choise). BUT BEFORE THIS, you suggest re-installing IOS236 using "IOS 236 Installer v5 Mod" (and that's what I can't find). This is supposed to be a seperate choice under the Homebrew Channel, isn't it?
    By the way, none of the files included in IOSvMod.zip are in my COPY_TO_SD.
    (IOS36-64-v3351.wad, and a folder containing meta.xml, boot.dol etc.)
  17. #59
    Aug 2010
    England
    Quote Originally Posted by StasisPm View Post
    I assure you they are the same in both files, IOS36-64-v3351.wad is on the root of the SD card this is used by IOS236 Installer v5 Mod. In SD:\apps there is boot.dol, icon.png, meta.xml and Readme.txt all with the same date and time.
    Keith
    2010 Golf GTD (170)
