I have a couple of clone Duos that I'm setting up. Have done loads before with no issues but these two are driving me mad.
The first came back from a friend who was having issues with blackhole and wanted VIX instead.
So I mistakenly downloaded Vix 2.4.9XX (non-clone safe) and proceeded to install this on his v2 clone. I installed all the essentials such as autobouquets, CCcam etc as well as 1channel. No real issues until 1channel crashed and proceeded to restart the box. The box simply loaded the splash screen and would proceed no further. All that was happening was the spinning VIX appearing and disappearing in the corner.
So I did a complete reinstall with the same image a number of times and this time left off 1channel. Did a hard restart with power button but the same issue occurred again. Anyway after a few hours and a process of elimination it seems that the non-starting issue seems to occur only when CCcam has been installed, I've tried different versions (2.13, 2.14, 2.30) and the same issue appears. I've tried this with Hard drive connected and disconnected as I was thinking it could be related to the hard drive but this made no difference.
I then found an earlier clone safe version of VIX (2.4.155) and no matter what I do the same issue is there. After a crash or hard restart the box is frozen on the splash screen.
I've since tried VIX 3.0 (clone safe version) and the issue remains. Could there be some residual remnants of the non clone safe software lurking somewhere on the system that is causing this problem or something else?
