fluorescent (13th April, 2013), Lusitanian1969 (24th September, 2018), miltisus (6th April, 2013), roby68 (26th October, 2013), semaca (22nd October, 2013)
why, when open the first time the program, open the free version, and when open the second time ,open registred version. can you help me ?
Thanks, it works very well.
Only Install and got registered version MultiEcuScan 1.3 !!!
I test on Windows 7 x64 !!!
linu, on witch version of window test?
- uninstall any other version on laptop
- delete manual any Multi.., Fiat... in program files (x86)
- update Framework
- install normal, not with administration
- and it work
another way use Loader Multiecuscan 1.2R1 works with Multiecuscan 1.3 !!!
- download Multiecuscan 1.3 from org page
- use Loader Multiecuscan 1.2R1 in front of this tread
-and it works to
third way is:
- install Multiecuscan 1.3 from org page
- rename multiecuscan on installation folder to multiecuscanORG
- copy these two files on installation folder :
Multiecuscan_1.3_exe_ese_files.rar
- run program !!!
Arno (31st March, 2013), oldboi (26th January, 2014), ROUTE6644470 (8th December, 2014)
test with windws xp x86 and not work
Another one MULTIecuscan, working 95% !!!
frogulator (3rd July, 2013)
what interface works?
Simply install !!!
albematty (15th May, 2013), Arno (3rd June, 2013), banetv (15th May, 2013), begesar (5th June, 2013), dopsleutel13 (9th May, 2013), FANOBD (21st March, 2014), giani03 (16th August, 2013), iekemen (24th November, 2013), kodiran (1st July, 2013), Meat-Head (16th June, 2013), miha99 (8th May, 2013), motocarlos (6th September, 2013), Spikyhercules (5th October, 2013), tinerfe30 (16th December, 2014), totalkey (10th May, 2013)
Multiecuscan 1.4 Patch
Step 1: Before multiecuscan 1.3 to install.
Step 2: Make the patch was then attached file.
Step 3: After Patch Install Multiecuscan 1.4
begesar (5th June, 2013), FANOBD (21st March, 2014), iekemen (24th November, 2013), motocarlos (6th September, 2013), piscinarasx (16th April, 2017)
Info before you install Multiecuscan1.4 from post 13 above make register clean .
copy this two red lines in texteditor or notepad and save it as multiecuscan.reg
Windows Registry Editor Version 5.00
[-HKEY_LOCAL_MACHINE\SOFTWARE\Multiecuscan]
klik on the ***.reg file you just made it and say yes to the box and register is ready for the new Multiecuscan
(maybe run as administrator depent on your UAC settings)
