Page 14 of 17 FirstFirst ... 491011121314151617 LastLast
Results 196 to 210 of 250
  1. #196
    Aug 2008
    Quote Originally Posted by kobol View Post
    yes i see and i read too. it's original 572 and 575 and i need clone 570, did u see different ?
    if you have 5.7 clone and its bricked then why not try the 5.7.5 dumps ?
    its not going to make it any worse, and if it does work, bonus
  2. #197
    Oct 2016
    becouse 5.7.5 not start software. ask certs. need 570 cloned dump to get it back live
  3. #198
    dadal's Avatar
    Aug 2015
    which version is now most stable ? I have 5.55
    need I to play with xprog or I can better stand by 5.55 ?
  4. #199
    Jul 2014
    Sofia
    I see here a lot of discussion about xprog and wanted to clarify some issues that I have with it. I tried to revive an old v5.0 by changing Atmega64 chip burned somehow.
    Changed the chip and programmed flash and eeprom. Tried to connect with 908AZ60 but no chance at all. After setting proper parameters I see with scope that xprog is sending the first SEC byte and is echoed by AZ60 back properly. After that communication stops. Did someone of you guys ever managed to establish connection with a 68HC908xxx ? I can read/write HC05 and HC11 on adapters properly and also HC912 (R/W both flash and eep) so there should not be a hardware issue.
    Any clue to read HC908AZ60 with xprog-m v.50 clone with blue pcb? Thanks in advance.
  5. #200
    makura's Avatar
    I am trying to downgrade my Xprog using a second xprog,after errasing i can't get write or read option to be active,its greyed out.
    Got it right finally
  6. #201
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    i did the same mistake how can repair it plz ??
  7. #202
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    hey bro. i lost all my authorisation after making update niw it com error communication help plz
  8. #203
    Jan 2013
    italy
    hi, I'm haunted by a v5.55 without usb xprog and it's certificate authorisation validation. I tryed to flash the atmega64a with what OP linked and another version found around here, but still the same error as soon as I try to read an eeprom. any ideea? thank you.
  9. #204
    Jan 2013
    italy
    I'm using tl866 icsp port to flash the atmega64 which completes successfully. but when I try to read and compare its content with what I just tryed to flash it's always different. should I consider the chip faulty? thx
  10. #205
    Feb 2013
    UK Bristol
    Quote Originally Posted by Utente View Post
    I had the same problem with fw 5.74.... with 5.51 was all ok. all verify sucessfull done, than with 5.74 had problems... i can't remember but with 5.55 was ok for me as well, but a lots person on this forum not recomended 5.55 because is not stable fw, better use 5.51 which is more stable and support list is close for 5.55. So try with 5.51 and software from Andre .......
    My post helps you? Please Hit Buttons
  11. #206
    GB
    Me too.I could not manage fw 5.74 to work,so I downgrade it to 5.51 and it works,but there is a few problems with this version too.For example mileage for vag dashboard does not work,but almost all other things does.
  12. #207
    Feb 2013
    UK Bristol
    I spoke one time with someone and he told me him 5.70fw is ok as well. But is hard find 5.70 firmware on internet and software which will be work without usb dongle...or maybe iam wrong so please correct me.
    So think good compromise is stay with 5.51fw at the moment
  13. #208
    Ukraina
    Where can I download version 5.7 or 5.7.2? (NO BOX)
    Nowhere is it ...
  14. #209
    Jan 2013
    italy
    replaced the atmel64 but I have the same problem, the readed flash is not as the one flashed (with the tl866a icsp programmer). plus I managed to lose the registration id and authorizations... anyone?
    edit: solved with ver 5.5.1
  15. #210
    Feb 2013
    UK Bristol
    This Is normal my friend, dont know why but have the same and xprog works correct.
    Example read dump from atmel64 and write this dump for atmel64... xprog doesnt work.
    So this means like backup from xprog, flashed later not work... wierd
    But work fw downloaded from.internet
    And if you see content from fw dowloaded from.internet and readed from atmel64 is diffrent as well.... sooooo
  16. The Following User Says Thank You to pocinas For This Useful Post:
    Utente (9th December, 2018)
