Hello !
Anyone have dump for atmega + software for xprog-m real version 5.45 or 5.48 with infineon and mac ?
I want to buy dump or about 10 programmed atmega's.
VAG
so I have a bit of a different problem. Some time ago I played with the 5.4.8 dumps that were posted here and now when I reflashed my knowingly working 5.0 project (that I used to fix my 5.3 that came with the device) - but still I'm getting "Device is silent" on Hardware info. I triple checked all the files I'm flashing and everything looks OK. The device shows up via USB and I install the correct drivers. Now I'm not sure, but it could be I tried connecting some separate power supply back then - could it be I got something fried? (visual inspection doesen't show much).
Also - the green LED should be on the moment I plug the device in right?
Any pointers would be appreciated,
XPROGM 5.3 with dongle eeror like in a pic any solution?
and program hangs
cant even cancel that screen need to go alt +del to get this off
koziolek (23rd April, 2014)
Hi, i have a problem when write hc11f1. Can read the chip, but when write, the most of attempt does it wrong and verify error appears. somebody can help me?
hi guys
my xprog 5.0 can read eeproms, but it can not read MCU, i have this error message " check bdm connections"
how can solve this problem?
Check errata
Hi guys!
I had Xprog-m V5.48 with Dongle that worked good for some time with Eeproms and some Mcu's (but not always), sometimes it gives "Device is Silent",
than it started having prolems with Eeproms too (Verify Error). Now it's giving " Error Check Connections VCC Pin Overloaded ".
I maked downgrade to V5.0 ( not from this thread ) and programming was ok but still having same error with all type of devices I try to read.
can anyone help me ??
sometime need:
or replace FT232BL
or replace ATMEGA64
or max232
last time, i replaced FT232bl to Xprog-Box 5.52
each time on a miscellaneous
Hi boys i will buy a xprog clone but i wondering which version is stable is 5.50 good or better buy an older version?
THANKS
Hello
i buy a xprog with version 5.3 with dongle , i try for instal , after instal run software , port detected but give me error
please see attach file
if possible please help me , what is problem ?
"" Access violation at address 00405394 in module 'setup.dat'.Read of address C08B02E4. ""
