post dump -= CODEDRADIO =- Base navigation
org dump files
93c76 -16 bit read
asliyucegsm and cars repair and notebook chipset repair
your dump bad.read again
attach a file to run me murat friend
code is stored and Mitsubishi processor M30833 (M32) for reading use SEGGER electronic programmer
COUNTER are stored in eeprom 93C76 !
Your dump is bad ,read again
Try tis....code off
ciptel07 (20th February, 2019), Decode Ghost (23rd June, 2017), kappa1 (26th October, 2013), murat332 (23rd June, 2017)
thank you my friends
93c76 code off
solved
Hallo i need code off to rcd500 please help.
i need code off for this rcd500
no can read mcu only can read eprom s93c76
http://www12.zippyshare.com/v/njy6HpSm/file.html
Hi try this dump
in 00015c change 17 to 00??
HI olmar
can u help with putting a code off on this radio as well or do i need to read M30879FKAGP processor as well. if so with which tool do i do so
eeprom 93c76
thanks in advance
