Passo use suzuki blade.
Smart card id 4c.
Cars can open with remote grabber.
This is a new Smart Card for a Toyota Passo. It doesnt come with the emergency key blade though, does anyone know what the key blade looks like for this key? Tried cutting a simple TOY47 Key to door but the ignition switch key appears to be something completely different, any ideas and more importantly a picture of the key if possible please? Have also tried programming this in with the TCODE but it wont even communicate with the vehicle, anyone know what tool I can use to put this card in to this car? Its just a prox card, no slot or anything in dash, thanks alot
Smart card id 4c.
here you go
this car is actually daihatsu sirion, guess the key blade must be daihatsu
muzzz (12th April, 2023)
Find immo box under right of steering you will find a 93C66 chip inside read it and post dump also read the remote and post the 4C key data from it.
Even if you cut key and it works in door it still will not turn into ignition unless the remote is program.
I will try to help you.
Yeh thats the problem I am having. I have programmed a 4c chip to the immo and taped it to antenna around ignition and pulled the electrical switch off the back of ignition and car starts with a screwdriver no problem now but you cant turn ignition switch when its back together. If the ignition key is just a plain metal key without any transponder (which as seen above i now know it is) then why is there an antenna around the ignition switch? How can i program the smart card? Unfortunately I dont have the original 4c chip from the card
but how do you get the ignition to turn without the smart card? I dont need the smart card at all? The ignition switch is strange on this car, it doesnt appear to have many wafers in it at all. I have cut a metal blank (same as the door) and cut the sides off it and it still wont work, heres a pic of the ignition in case we are talking about a different type
I made note of this before in another post here.
One the ignition cylinder there are 2 different switch, one closer to the ignition Key entry point and another further down for the Twist knob.
Once you put a key with the right chip into the ignition here is what happen step by step
1) The key when inserted into the ignition switch must first close the curcuit on the upper chime switch.
You will hear the chime if the door is open, if you dont hear it then you MUST check it with a Ohm meter to ensure that it is working. If the chime switch is BAD you MUST bridge the circuit to trick the computer to think the mechanical key is alway into the ignition.
2) Once the upper chime switch is activated the Immo box now send the signal to the antenna looking for the Transponder chip and once it see the correct chip it will UNLOCK the ignition cylinder by sending power to a solonoid at the back of the ignition cylinder housing.
3) Every time that you either insert the correct key into or near the antenna ( with the chime switch activated ) you will hear a "TUCK" that is the sound of the solonoid as it unlock the ignition cylinder.
4) As far as the Keyless remote goes, once it enters the car it will autmatically unlock the same solonoid mention above so that the knob can turn
5) The second chime switch is activated whenever you depress the Twist Knob and is used to tell the immo ecu that you are have depress the ignition knob so if it senses the keyless remote then enable start.
6) All the keyless remotes that I have seen so far for this system HAS a 4C transponder inside it every single one.
If yours is not reading as a 4C try reading it at different angle if not then the remote is no good.
7) You can treat the keyless remote like a regular key that you can hold close to the antenna the insert any mechanical key into the ignition that will trigger the chime and start the car, A uncut ignition key can be used.
This I do all the time and it works 100% every time.
Finally I am still trying to find out how to program the Keyless Remote but no luck yet. I am told it can only work with a NEW immo Box or a Vigin dump on the immo box so I will test this theory on my next job because I now know how to make immo box VIRGIN.
Hope this helps my friend.
abvayani (2nd June, 2014), kyawkyaw (2nd May, 2017), PocketHero (26th September, 2018)
Without the key blade you can rotate the igniton switch.
Needed transponders located near the ignition switch hole.
how to reprogram this remote key pls help me thnx
never lost anythink only change ...
