Cuberevo Series Multibooting Config file
Results 1 to 15 of 27
    aftermath's Avatar
    Mar 2008
    Default Cuberevo Series Multibooting Config file
    If you want to multi-boot, download attached usb_config.img.
    Then press number button on RCU which you want booting mode.
    Multi-booting support as below.
    1) boot from cdkroot
    2) boot from USB with hdd
    3) original images
    4) boot from release
    5) boot from USB without hdd
    6) boot from SATA hdd
    7) boot from flash
    aftermath's Avatar
    Mar 2008
    also these :
    Mar 2009
    Hi Aftermath,
    Where do we upload this to?
    Mar 2008
    just up it to the reciever via pc editor,word or warning though i could not connect to the internet with box using these so did the bootargs manually
    aftermath's Avatar
    Mar 2008
    I agree, the bootards manually is a safer option.
    Feb 2009
    I can't get my PCeditor to talk to my IPBox 9000.
    Is there an oyher way to flash this multiboot to my box
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by aldiverse View Post
    have you set up PC editor correct, in tools menu .
    you need to set correct IP address for box
    username and password.
    then have a usb printer cable , one end in back of bow, other end in PC usb slot.
    switch box off at the back
    press and hold in the on/off button at the front, then switch on at the back, hold the button in until you see "USB UPGRADE "
    another way is to format a usb stick
    put the multiboot image onto it.
    How to upload this config to cuberevo 200HD? It has no serial connection.
    Noob alert, but is there any way to check that multiboot is active since pressing keys on the remote doesn't seem to make something happen for me.
    I've flashed with the lastest SIF/dgs image, and then downloaded the multi-boot image, "usb_update" seem to have worked, I got "done" in the display
    Am I missing something?
    This was on a cuberevo 250hd
    May 2009
    Default how do we change the image
    How do we upgrade to a new image for cuberevo 9000?
    After doing this and before FTP the E2.img to the USB, have we got to do some thing to find the /mnt/usb/usb0...
    That means how to to mount the USB stick with the Telnet?
    A Howto (Step by Step) will be helfull for all people.
    Best regards.
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by nabilg View Post
    Best regards.
    format the USB stick to ext2 using Paragon partition manager. i use 2 partitions on my sticks.
    if you search the forum for it , you will be able to download it from here.
    then put the stick into the box and switch it on, when it boots up it will find it .
    then if you ftp to mnt/usb/usb0 there should be a lost and found folder, then you will know its ready to ftp the image in mnt/usb/usb0 folder.
  13. #13
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by johnthomas View Post
    i find the easiest way is to use PC editor. make sure you do a ping test and PCeditor can comunicate with the box..
    get yourself a usb printer cable, printer end goes in the back of the box and usb end into the PC..
    switch the box off at the back and press and keep the front on/off button in until you see the words " USB UPGRADE " in the LCD.
    now tell pceditor you want to flash the box, and point it to your desired image. then ok.
    it will go through 3 fazes , Erasing, uploading, then flashing.. it will say done when its finished, then switch off the box and back on to boot up..
  14. #14
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by edcka View Post
    put it onto a usb stick ( make sure its a nice clean formated one ), then do same procedure as if you were flashing a new image to the box.
  15. #15
    Hi everyone,
    I still cannot download any multiboot file on this site.Does anyone knows why ? Thank you
