ECAS 03012 Man tga
Results 1 to 5 of 5
    DK Veteran dimitar22's Avatar
    Jan 2009
    Default ECAS 03012 Man tga
    Hello
    I have problem with man tga ECAS 2.
    Tried to calibrate the ride height using man cats, during calibration i turned off the ignition by accident.Now i have error code ECAS 03012.
    Now i can not calibrate the height and the fault code is active.
    Please help.
    The truck has to leave tomorrow.
    Jan 2013
    Bulgaria
    03012 ECAS . Control unit (checksum calibration data travel sensors)
    Disconnect battery wait 10min. Clear error codes. Calibrate again. I have instructions for calibrating the Bulgarian language may send.
    Regards
    Jan 2009
    please send the instructions i will translate them.
    Jan 2013
    Bulgaria
    Calibration of the Bulgarian!
  5. The Following User Says Thank You to Biser Kulinov For This Useful Post:
    Joca85 (18th January, 2022)
  6. #5
    Dec 2017
    Hello bizer dou have the same instructions about the 3012 ecas.i also got the same issue.
