Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
  1. #16
    Jose19's Avatar
    From the HELL
    Quote Originally Posted by ninja123 View Post
    you dont need to adapt any keys, I wrote your keys into the dump, you just need to learn ecu.
    ninja
    Hi friend
    The car is runnig now, your solution worked 100%..
    My fault is i havent learn ecu.
    Great job from you Ninja
    BR
    Jose
  2. #17
    west mids, uk
    Default aveo immo
    Glad to be of help mate, I had this same problem just last week, so all info was fresh in my mind!!
    Nice to get a reply too!!
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  3. #18
    Jose19's Avatar
    From the HELL
    ninja
    Many Thanks Friend
    BR
    Jose
  4. #19
    Hungary
    Aveo ECU teaching enough to dump the flash, or should Tech2?
    This is similar to the ecu renault sirius32
  5. #20
    europe
    I have same problem with 1.4 delco ecu try to tech ecu with mvp but with no success is there some other solution to propose ?
    Thx
  6. #21
    DK Veteran teuton's Avatar
    Mexico
    Quote Originally Posted by VDO View Post
    Thx
    Did you write your keys into dump before you tried to teach ecu?
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  7. #22
    keygargoil's Avatar
    here is your file try this there is a new file also incase yours is bad
  8. #23
    europe
    Quote Originally Posted by teuton View Post
    Yes I'm, I have only one key, in mvp menu sad that immobox is learned with the key
    @keygargoil password my friend
  9. #24
    Hungary
    aveo 1.4 delco can you immo off .
  10. #25
    May 2011
    I also have the same problem with aveo, but I wanted to download your files and secure? password?
  11. #26
    May 2011
    file.. for gargoil
  12. #27
    keygargoil's Avatar
    send me your key data and il add it for you i think you just need yor key programming as there is no keys
  13. #28
    Hello, I have the same problem with aveo 2011, I have both keys and inmo flashes, here I send inmo file, can anyone help? delphi ecu 34 mt. thanks in advance.
  14. #29
    Hello , ninja123 , you can check my post and tell me which may be happening to you, thanks .
  15. #30
    Jan 2017
    try this dump, then do learn procedure with mvp, then re fit obd plug cover before starting.
    ninja
    ninja123 please can you repair this immo box thank you my firend
    chevrolet kalos 2006
    93c56.rar
