Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
    Jose19's Avatar
    From the HELL
    Default Chevrolet Aveo 2005 keys problem
    Hi to all
    Is possible to synchronize this two keys directly in to dump file, ready to start?
    Those keys are original from the car but dosent work, the car was dead batery and now dosent start because of immo.
    I have try to re-synchronise with MVP but not work.
    Here dump file from immobox and ID keys;
    Remote key B6 43 AE 23 AF 65 87 65
    Normal key B6 42 1E 8F A3 7D 87 65
    Many thanks
    BR
    Jose
    obdmaster's Avatar
    Never never land
    Usually when battery goes flat on daewoo/chevrolet, the immobox goes out of synch with engine ecu. Use MVPpro to re-synch immobox to engine ecu. If you havent tried already m8
    You need every tool in the book, to do this auto locksmith job.
    Jose19's Avatar
    From the HELL
    Quote Originally Posted by obdmaster View Post
    "..... I have try to re-synchronise with MVP but not work...."
    DK Veteran rashid01's Avatar
    UAE
    frist all fuse and try synchronise with sbb
    UAE
    check all fuse and rely
    Jose19's Avatar
    From the HELL
    Quote Originally Posted by rashid01 View Post
    All fuses and relays are ok, the problem is keys, i dont have SBB only MVPpro.
    BR
    Jose
    west mids, uk
    post a picture of immo box, i just done one like this and dump was corrupt, you need good dump and re sync ecu with mvp, add your old keys with zed.
    ill make you a good dump later....
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    Jose19's Avatar
    From the HELL
    Quote Originally Posted by ninja123 View Post
    ninja
    Here friend
    I apreciate your help.
    BR
    Jose
    west mids, uk
    Default aveo
    try this dump, then do learn procedure with mvp, then re fit obd plug cover before starting.
    ninja
  10. The Following 3 Users Say Thank You to ninja123 For This Useful Post:
    ashraf2000 (8th June, 2019), foxx (26th August, 2021), webastocu (14th February, 2020)
  11. #10
    Jose19's Avatar
    From the HELL
    ninja
    Thanks friend
    I will try as sun as possible and give replay.
    BR
    Jose
  12. #11
    Jose19's Avatar
    From the HELL
    Hi friend
    I have try, but no succes, MVP find immobox, but when i try to adapt keys keep saying " please wait ..trying to comunicate.... " for long time and dont make anything.
    What do you thing aboat this?
    BR
    Jose
  13. #12
    richard27's Avatar
    Aug 2011
    Default chewrolet key add
    transponer tip : 48
    id:1.key B6 43 AE 23
    id:2.key B6 42 1E 8F
    If the data they need to work towards try
    ​information sharing
  14. #13
    Macedonia
    Here is example for key and immobilizer dump.I had problems and I solvet it after replacing 93c56.Some programmers read 93cXX swaped.
    Synchro with T300
  15. #14
    Jose19's Avatar
    From the HELL
    Hi friends
    I will try and give report
    BR
    Jose
  16. #15
    west mids, uk
    Quote Originally Posted by Jose19 View Post
    Hi friend
    BR
    Jose
    you dont need to adapt any keys, I wrote your keys into the dump, you just need to learn ecu.
    ninja
