Citroen C3 HDI Non Start No Communication ECU - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 58
  1. #16
    Dec 2011
    Nottingham
    Hi all.
    An update...
    Joined the CAN lines of the ABS In/Out. But apart from no communication with the ABS Module everything seems to be the same. I have also given the BSI a tap!
    So before I order a new BSI I will go with what Dunker and rachmach suggest and make sure power is in the correct locations.
    mcabd and busaman - were you refering to the BSI in glovebox or BM34 under the hood?
  2. #17
    busaman's Avatar
    suffolk uk
    bsi is in the glovebox
    7.31sec@203.3mph
  3. #18
    busaman's Avatar
    suffolk uk
    have you checked the wiring to ecu from the bm34 they also give problems the double engine control relay is in there.
    7.31sec@203.3mph
  4. #19
    Dec 2011
    Nottingham
    Yes I'm just working through the wiring diagram, making sure I have continuity on all wires. Looks like the BSI is the culprit though...
    Will keep you posted, thanks
  5. #20
    busaman's Avatar
    suffolk uk
    have you got the rp no and vin does it have esp il look up the propper wiring diagram for you.
    7.31sec@203.3mph
  6. #21
    Dec 2011
    Nottingham
    N/S sticker reads:
    11194CA
    10540
    EZWC
    1184540
    VIN: VF7FC8HZC28955568
  7. #22
    busaman's Avatar
    suffolk uk
    here is the diagram for your car.
    7.31sec@203.3mph
  8. #23
    busaman's Avatar
    suffolk uk
    would help if i attached it
    7.31sec@203.3mph
  9. #24
    ABS is a part of serial CAN bus system. It's not just link a twisted pair. Ther are end line resistors and it has to go through ABS system. Check your resitance between CAN lines on abs plug is it 60 or 120 ohm ?
  10. #25
    busaman's Avatar
    suffolk uk
    trust me you can link the CAN wires on the abs to eliminate it as a problem ive done it several times.
    a fault in the abs can cause all the modules to loose comms, ive seen it on c3 c4 c5 models.
    7.31sec@203.3mph
  11. #26
    Meat-Head's Avatar
    Quote Originally Posted by busaman View Post
    OFF TOPIC:
    vectra C, Zafira B, Saab (?
  12. #27
    busaman's Avatar
    suffolk uk
    OFF TOPIC:
    yes meaty can-bus can do strange things one module can show lots of errors on others. but pug /citroen with van-can can have one of the wires broken but still work with reduced perfomance but you wouldnt know it. until you ran a test on the can-bus.
    7.31sec@203.3mph
  13. #28
    Dec 2011
    Nottingham
    Thanks, I'll jump back on it today and report!
  14. #29
    Dec 2011
    Nottingham
    I pushed this to the back of the garage, but back on it now. Wiring appears to be correct. So I've ordered a BSI. Hopefully that'll do the trick. Will report when it arrives. Thanks
  15. #30
    Dec 2011
    Nottingham
    Just stripping the old unit out, its a 96 592 854 80 same as in Peugeot 207. Can these be code swapped?
