Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 58
  1. #31
    busaman's Avatar
    suffolk uk
    no the immo code is stored there also if you plug it in the speedo jumps to the one with highest milage.
    7.31sec@203.3mph
  2. #32
    Dec 2011
    Nottingham
    So new unit only?
  3. #33
    racin-snake's Avatar
    Jun 2009
    no you can swap the memory or virginise a second hand bsi and has the same hardware nos from the old bsi (if you have the tooling to do so)
    reprogram bsi with lexia or something similar swapping the memory would be cheapest option if you have the equipment to do so
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  4. #34
    Dec 2011
    Nottingham
    Excellent thanks. Which eeprom holds the data? Or is it on a flash?
  5. #35
    Oct 2012
    Last month, I had the same problem with 206 1.4hdi,and you've tried all that,bsi ecu key from other car,but it did not help.at the end of the fault was very stupid.engine ecu he lost contact in plug(white and green wire) can bus
  6. #36
    Dec 2011
    Nottingham
    Hi all,
    I need to finish this car so I've got myself a known working BSI with the same part numbers. Can someone please help me as to how I can code swap them please?
    Can it be done with upa?
    I've attached images.
  7. #37
    Meat-Head's Avatar
    word on street says yes UPA 95160 - in the middle of the board.
    Was having a late night discussion with Vic down the pub - were were discussing that for somereason not all the vechile data is stored in the EEPROM.
    Best thing you can do is go stalk somebody from the milage IN-coreectopn dept. and ask for the pin soldering points.
    so you can have a go but a bit dubious about sucking and blowing in-circuit.
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    Autowave (26th March, 2013)
  9. #38
    Dec 2011
    Nottingham
    Cheers meat head, I'll have a gander around that section. Right after I smash a few more pints of Guinness down!
  10. #39
    maaxxyy's Avatar
    North Pole
    mileage is stored in the atmel25128 on this bsi, immo i think is in the hc912. i have one which i'm still trying to sort out, but theres no data available for this bsi yet.
    One thing i would be doing on this car is bridging the can lines at the abs pump, ones from ecu to abs and ones from bsi to abs and see if she starts!!!!!
  11. #40
    Shmortz's Avatar
    in the middle of nowhere
    few days ago I struggled with this problem, there was desoldered pins to GND in ECU, try to put GND at the ECU housing, will work if there is a problem ...
  12. #41
    Oct 2015
    I have same problem. What is the solution for this?
  13. #42
    Dunker's Avatar
    Yorkshire
    Were the power feeds ok? In particular the EC relay control wire from ECU to fusebox. ECU switches this wire to GND to switch on the EC relay in the fusebox which then feeds the ECU with power.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  14. #43
    Oct 2015
    Can you explain more please? I don't find what wire or relay is.
  15. #44
    Dunker's Avatar
    Yorkshire
    As per your P.M. :
    This isnt the diagram for your ECU but yours will be similar. The EC relay (engine control) is controlled by the ECU. Assuming your ECU has all its other power supplies that are OK (any perm live(s) and IGN live) then:
    The ECU will pull wire 1229 via pin Af1 down to ground which turns the EC relay on. The EC relay then supplies power to wire 1203 which goes to Ah2 and Ag2. When these 2 have power the ECU is fully powered and will talk on the diagnostic. The EC relay will probably be built in to the engine fusebox and is not accessable. So you will need to have the right diagram for your ECU.
    If no diagram available then look at manuals for things like FGTech or MPPS to give you an idea of what needs to be powered to get the ECU talking on the diagnostic.
    Easiest way to test with the ECU plugs out of the ECU is to use a 21w bulb and use this to ground the pins you find that are live on the ECU plugs. A good live will light the bulb and if its a relay feed that needs earthing the low resistance in the bulb will earth the relay coil and you will hear it click. Once you have heard the relay click you are safe to earth the pin you are testing and then you can look for the new wires that have gone live with this relay energized. The bulb should light when testing these new live(s).
    (You have scoped the CAN Bus lines to the ECU to make sure data is gettng to it?)
  16. The Following 2 Users Say Thank You to Dunker For This Useful Post:
    Meat-Head (23rd July, 2018), Perryking (24th July, 2018)
  17. #45
    Meat-Head's Avatar
    Or feed the THICK blue or pink (NOT THIN OR GREEN/yellow) wires on fuel pump and stand back
    crank and hit under fusebox with big wooden stick
