I INSTALL THE SOFTWARE IN TO PC THE RESSALT
ACTIVTION ERROR
THINKS
i have 2 original interfaces among others and i had problems with them( they are the old ones with the usb b male connexion)
the one had a problem with the usb port( the cable could not attach in the port) and i had a message that the device could not be recognized.
and the other had 2 wires cut in the cable between obd plug and the round 30 pin plug.
check those and if you have cut wires i can make a diagram if you like, cause all cables are white
ACTIVTION ERROR
THINKS
Update V7.06
But Be Carful Read the install instruction
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
Hey guys!
I'm sorry for double posting, but...
Have anyone this issue?
Regards!
Hi everybody,
I have a strange problem on Lenovo laptop.
When I try to activate Diagbox 7:02 I am getting the message: Failure of the activation (error 0)
On the laptop has been installed version 5:02 and it worked OK.
I tried with a newly installed XP Pro, but with no luck.
V7.02 I installed on another 2 laptops (Dell and HP) and it works.
Thank you Namek.
I will try today and report.
Dont see links for update files...
think his updated first post http://www.digital-kaos.co.uk/forums...d-files-2e.doc
I just made first test.
On another partition I installed Windows 7 32bit.
I used the same settings as for XP.
-all drivers installed
-no internet connection
-language settings = Croatian
-install Diagbox 7.02 from ISO file using PowerISO
Result:
-activation OK
-installation Lexia and PP OK
-test on car (C5 restyling) OK
Currently doing fresh installation of XP with LAN drivers only.
I will inform you about success (or failure) of this mission.
How do i update my lexia interface to use diagbox software?
thanks, ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
All my attempts to install Diagbox 7.02 on Windows XP have failed.
I have tried:
-with internet connection
-without internet connection
-with all drivers installed
-with only LAN driver installed and internet connection
-installation from ISO file
-installation from DVD
-3 different versions of Windows XP professional
-playing with bios settings (virtualization settings on-off)
-and various combinations
Always getting this message: failure of the activation (error 0). On same laptop with Windows 7 installation goes without any error.
Laptop is Lenovo Thinkpad Edge E325.
The only solution for now is a dual boot XP-7.
have u got all your Microsoft .NET Framework installed 1 to 4
