And ..............Update V7.42
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
Anybody can help me out?
I install ver. 7.02 - no problems, everything works.
I install ver. 7.06 - and it tells it can't discover car.
I did a clean install 2-3 times - same thing every time.
Checked firmware with checker - it updates to 4.3.0 and to 4.3.2 when I install higher versions but no communication with car(tried with different Peugeot cars and PP2000 module).
Thanks but I already tried doing that APPDIAG.sys trick(I've read all the warnings - it's hard to miss them). Still no good.
This APPDIAG.sys back up is about the licensing, not the communication, right?
Restarting pc everi time after updating? And lexia olways plugged in usb when updating?
New update V7.43
added to make a clean install Update V7.XX to V7.43
You can use it from whatever version you Ar on
Version 7.01 or 7,02 or 7.09 or .................. what u want
alfabug (19th May, 2014), ancient (28th May, 2014), autoTkey (21st May, 2014), bibkare (2nd June, 2014), drzeng (19th May, 2014), gazvts (19th May, 2014), genius76 (19th May, 2014), javornik (19th May, 2014), jos68 (19th May, 2014), kitty-hawk (19th May, 2014), Master01 (19th May, 2014), mesrine_29 (19th May, 2014), paro44 (19th May, 2014), shirokov (11th June, 2014), super-cab (29th May, 2014), xilophene (20th May, 2014), yellowstilo (22nd June, 2014)
Great work scarymistake!
genius76 - yes, but .... it seems the tool has given up - tested on other computer where installation is working and it's still no good, so it's probably broken. Comm to the tool is OK but no comm to the car.
If you can check again vci checker is it rev B or rev C ?
New update
look at first post (7.44)
alfabug (31st May, 2014), Elektrik001 (1st July, 2014), horst-hirsch (25th June, 2014), javornik (6th June, 2014), jos68 (30th May, 2014), kitty-hawk (29th May, 2014), Master01 (29th May, 2014), move (20th June, 2014), paro44 (2nd June, 2014), shirokov (11th June, 2014), sumi1 (2nd June, 2014), xilophene (29th May, 2014), yellowstilo (29th May, 2014)
autoTkeytry please reflash your psa interface with the PSA REFLASHING INTERFACE from section download,and make from there version 4.2-0...or other....after that,start diagbox without usb interface connected...connect this only when is the black desktop
We are back in business with the help of LuisAndre ( http://www.digital-kaos.co.uk/forums...228-luisandre/)
Today i release update V7.46 already patch
Alll credits go to Luis-Andre
Master01 (5th July, 2014), paro44 (7th July, 2014), xilophene (5th July, 2014), yellowstilo (5th July, 2014)
