Hi friends i have a issue and i dont understand the problem,my cluster shows on the ODO 9999999,everything is correct with the cluster,all works ok and no faults,also the bsi is brand new coded,its 0 km.i already change the dump in cluster and its always the same thing 9999999 anyone have an ideia about this issue??
car runs ok,all work!
citroen xsara picasso 1.6 nfv
year 2001
better put yours dumps..
regards
cool once the milage goes over think 600K MILES the clocks LOCK.
so suggest you zero the bsi then try LEECHING a dump and IN-correct to what you want.
it maybee your speedohead dump is now gone to 'stuff you' mode.
i killed a set of clocks by accidnet
cost M-H-M ?65 for a second hand head
no,it was on 99999,this car has a long story,it goes to citroen because some guy burn the bsi and the ecu,in citroen they have change the bsi,so its new,but car dont run,and now it came to me,i put the car running,now i got no faults,all works ok,but it shows 999999,have to say the instrument its from another picasso.
yes that new BSI is now got 9999999999 in it, so not matter what you do you HAVE to zero the bsi and reset the clocks.
as the clocks are out of something else i would LEECH a dump off here and edit that if you can
just incase the 'locked' bit is in your dump still.
another thing,i have one from scrapyard bsi and this one have 218000 km,and on cluster is always on 999999,why??the instrument have to read the bsi rigth??
bsi must be reseted and good milleage in dash only way to work...
Sorry of iferion site
But maybe will help to understand
Google Translate
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
Friend the solution of the problem is easy
should put in virgin bsi file and swap file dashboard
while you do not change the file bsi any dashboard that you put vai playing km to 999,999
I am sending the file from virgin bsi
carmansk (13th November, 2014), dreamboxservice (25th October, 2019), gojko (11th April, 2014), jnoroeste (17th August, 2023), johan240 (21st January, 2014), losing.control (21st January, 2014), M.Jojo (20th September, 2020), pollito128 (12th January, 2017)
i have bsi valeo in picasso 2001 with tacho vdo 93c66.
please how read bsi ??????? i need write file virgin
You can get 999999 km on display when BSI don't communicate with dash through VAN
Autodiag11 (2nd February, 2024)
