Results 1 to 4 of 4
    Feb 2013
    Default Advice re watching ESPN
    I ditched SKY due to cost and instead bought a Samsung SMT S7800 freesat box and it provides a very decent picture. I wanted to get ESPN so I have ended up with a T215 topuptv box with ESPN card. The picture quality is however below par, despite having a decent aerial. Can anyone recommend a replacement freesat box, as good as the Samsung, but with a card reading facility for watching ESPN. It may well be that I cannot do that so any advice welcome.
    Thanks in advance.
    Nov 2008
    Quote Originally Posted by buckielugger View Post
    Thanks in advance.
    I dont think your subbed card will work on freesat, so dont think its worth recommending any box for this (for your present c@rd)
    you can use satellite boxes for freesat and many have a c@rd slot in which case the subbed version of your card but for satellite should work, and I would recommend a HD box for this, like a spider or blade or vu or dream or anything similar
    if your signal is via your aerial (which it is for topuptv) then I dont think any of this is relevant in the freesat section as freesat comes from a sly dish pointed at 28 east
    Mar 2009
    Warrington, Cheshire
    I thought TopupTV was FREEVIEW, not Freesat.
    As mentioned above to get Espn on satellite to you would need a white card with Espn enabled (paid for) & you could possibly use the above mentioned boxes also a TM5402HD to add to the list.
    But i also think you need to have some extra packages to get Espn aswell so it will soon rack up the price.
    I think you can get Espn on freeview though without buying any extra channels.
    Oct 2008
    Quote Originally Posted by rigsby71 View Post
    most televisions lcd---plasma---have a cam slot on the side . you can get a topuptv cam module that allows you to put your topuptv card into this allows you to watch the topuptv--- espn channel using the freeview tuner that is built into your tv . this may be a sharper picture ? depends really on the tv
