Results 1 to 4 of 4
Thread: UK epg
    Feb 2013
    Default UK epg
    I am hoping that someone can give me some advice regarding the epg. As I am in germany, I currently only receive the program on now and what is coming on next in the epg for the UK.
    Is there a way that I can change this? My solo2 is from germany (maybe this makes a diffence to the epg, as I remember I had to purchase a box from the UK before to receive the full epg, although that was not a linux box).
    Sep 2008
    i would have thought they have different countries to select the location for the epg like rytec germany/austria/swiss xmltv
    in under the cross epg-xmltv.
    if you were in uk use the uk version.
    digicon's Avatar
    as Cactikid has mentioned you have the choice of using the Rytec direct download servers or seeing as you are receiving the 28.2? east signal you could download it directly from the OpenTV download again located in the EPG section, Only difference is OpenTV takes the EPG direct from the Transponder instead of from an online server database
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Keep up the good work digi doing much better now a moderator.
