To adopt RB4 cluster you need to have Virgin new/used dash , otherwise it will not adopt.
Also this can be done only with IMMO3 Immo 4 is different story.
please help with pin for audi a4 2005 crypto cluster.
on engine ecu it is 65210 but it is not accepted on ic to add key adaptation
I did engine 95320 with several calcs and pin is correct it is accepted on vcds.
I can't read ic over obd. Vag tacho5 or can k command dose not read. Vag eeprom programmer says pin found and ressets cluster, but dat file is empty.
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
incar (21st April, 2018)
Thank you for confirming engine ecu pin.
Ok let me rephrase, why it is not accepted on IC to add adopt key?
It is audi a4 2005 end with bosch rb8 cluster
and why non of obd tool apart of vcds can connect?
Is it K or CAN based?
Reality of life :
3:Everyone lies
Thanks! But what you mean by all this?
I have 8E0920951K
I have Megamos Crypto ID48 precoded for Audi TP25. but how to code it on car if login is not accepted?
Reality of life :
3:Everyone lies
I did on both 17 an 25 all is same no difference.
Should I do 13861 first?
You have rb8 cluster with immo 4 and not possible with VCDS to program key .
Only Immo 3 .
