Results 1 to 15 of 17
    Default CUMMINS CM2150C need calibration file
    Could somebody help - I have broken CUMMINS CM2150C control unit, is it possible to get correct calibration file for it? All the stickers below
    P/n 4943133 ESN 69910658
    S/n 4623 D/C 2008.02.22
    E/c AX90022.05
    Continental CM2150C
    P4943133
    2150CF004623
    T3077
    It's from China truck DONGFENG, 340 ps.
    At the moment truck uses another ECU from 310 ps similar truck, but has power loss (guess why)
    Is it possible to program new calibration to it to solve the power loss problem?
    Thanks alot
    DK Veteran jctech's Avatar
    just beyond the edge of reason
    Quote Originally Posted by bynow3 View Post
    E/c AX90022.05
    Continental CM2150C
    P4943133
    2150CF004623
    T3077
    Thanks alot
    Use this information to get the cal file from the InCal CD Rom, download from the thread on this site
    Cal code - AX90022.05
    BASE ENGINE INFORMATION UpfitOriginal Engine Serial Number69910658 Vehicle ID Number
    Shop Order #SO60146 PlantDFM - DONG FENG MOTOR - JV Build Date25 Feb 2008 Warranty Start Date
    Customer Number99999 Customer Name
    ECM Code AX90022.05 Fuel Pump Part #4921431 Fuel Pump Calibration
    Film CardZ Engine Config #D563003BX03 CPL #CPL1979 EPA Model Name
    Marketing Model NameISL-350 Service Model NameISL CM2150
    other useful info if you want to choose a different calibration code
    SC 97693
    DO 90851
    FR 92144
    CPL 1979
  3. The Following User Says Thank You to jctech For This Useful Post:
    bulbox (9th August, 2023)
    Thanks mate,
    I have one more problem - how can I load to used ECM that contains anothe cal file? Insite ask me for password, because old cal is 90020 but new cal is 90022... Insite says me to ask local distributor to obtain authorization code for next data:
    Asked cal AX90022
    Serial no ECM 5090
    ident hardware C879A3C2
    Any help?
    PS Password looks like
    DK Veteran zds's Avatar
    Russia
    Thanks mate,
    Asked cal AX90022
    Serial no ECM 5090
    Any help?
    use fleet calibration counts password for insite to calibrate
    also you can upload calibration with calterm. see your calibration in attachment
    thanks ZDS,
    but I haven't Calterm installed, mb later I'll try to do so. By the way where/how can I get fleet calibration counts password?
    Russia
    thanks ZDS,
    post your insite ID
    As I can guess
    hw-id C879A3C2
    Russia
    As I can guess
    hw-id C879A3C2
    FSSEB66E666D86457U
  10. #9
    And for ECM password removal, please...
  11. #10
    DK Veteran vicente456's Avatar
    Nov 2012
    colombia
    ECM PASW WSS6E64737C983E4O4
    OEM PASW ZSS54327CF9E6394O0
  12. #11
    Brazil
    Friend I have a problem in a module Cummins ISL engine 390cv CM2150E need a calibration file without EGR and without bluetec.
    the carrier is a truk vw
    could help me with this file can be read by bdm file or file for record with the Incal
    I am very grateful to you guys is helping me a great day for all
  13. #12
    Roy Suryadwiananda's Avatar
    Indonesia
    Hello ,
    Apologize if it is not related to this thread, but can I asked for help Calibration file for Cummins ISX 475 CM 570, ECM Code: N11057.16, ECM P/N. : 3408501, DO Option : 1096, SC Option : 10447, ESN : 79605085 , that have not expired.
    Thank you.
  14. #13
    Senior Member kitty-hawk's Avatar
    FRANCE
    Hello Roy,
    N11057.zip
    Regards,
  15. The Following User Says Thank You to kitty-hawk For This Useful Post:
    Roy Suryadwiananda (27th May, 2013)
  16. #14
    Indonesia
    Quote Originally Posted by kitty-hawk View Post
    Hello Roy,
    N11057.zip
    Regards,
    Hi again,
    Thank you guys, I've done recalibration and success.
    Happy on Monday.
  17. #15
    May 2012
    Hello Friends,
    Could samebody help me with calibration file for Cummins CM2150E.
    ESN: 21948407
    ECM P/N: 4995445
    ECM code: CJ90030.13
    Thank you in advance !
