Results 1 to 8 of 8
    Sep 2010
    Default RB4 Crypto PIN reject Audi A4 B6
    I have problem with A4 B6 immo - Need to program new key but cannot read correct PIN code.
    I have read PIN with Carprog, Vag Dash. I read ECU and always get the same result - 07466. Reads should be valid as mileage matches.
    Problem is that cluster always rejects the pin code. At the same time it works for ECU.
    Immo is working, VIN perfect match in tacho and ECU.
    Car:
    Audi A4 B6 8E
    year 2003
    2.5 tdi quattro AKE 132kW
    Cluster RB4 Crypto 8E0920930K
    Where is the problem and how to solve it? Which tool to use for correct PIN read?
    BR, Jonix
    Feb 2011
    Leave ignition on for an hour, then adapt keys without switching ignition off.
    richard27's Avatar
    Aug 2011
    I looked at you with a program dump you pin 15834 look like, but I'm not sure
    ​information sharing
    Sep 2010
    Is it possible to clone transponder?
    Sep 2010
    Quote Originally Posted by workdamnyou View Post
    Thanks. Seems it worked. What is the reason for this waiting?
    Feb 2011
    Not possible to clone transponder, at the moment.
    Immo was locked out due to ignition on/off with an unprogrammed key.
    Sep 2010
    Login did not work even with coded keys (did not use new).
    After waiting worked like a charm.
    Thanks one more time.
    Feb 2011
    You're welcome mate.
    Reading the pin may have locked it out also.
