Page 1 of 5 12345 LastLast
Results 1 to 15 of 61
    Jan 2013
    Smile ALLISON D0C V8.0.0
    Hi can some please help me out with password/unlock for allison v8.0.0 key: 173888717388
    and the reprogramming key is :1001585664 and i would also need the password for this if possible. thak you in advance
    Aug 2011
    USA
    Quote Originally Posted by djdiesel View Post
    Key 1425162524232071891817
    Reprogramming Key 1298916211415149
    Jan 2013
    THANK YOU AGAIN, THAT AWESOME, THERE IS TWO OTHER KEYS FOR ENGINEERING USE ONLY AUTHORIZATION KEY IS 1001585664 AND THE OTHER IS ADMIN PARAMETERS KEY 1000261856, I FIGURED IF C IF YOU CAN GET THOSE PASSWORDS
    Senior Member kitty-hawk's Avatar
    FRANCE
    AUTHORIZATION 1001585664 => 112928916211415149
    ADMIN 1000261856 => 112928710176191213
    I've got an Activation Key for 8.4 of 468505946850 that I could use a Password for and a Reprogram key of 1002602626 that I need a password and Serial #. I had 8 and then upgraqded to 10 and activation is a mess so I went back to 8.
    Thanks in advance.
    This is a double post for I didn't realize I posted in the Allison 9 thread.
    Kitty Hawk. Couldn't get my 10 working even with new activation so i went back to 8.
    Aug 2011
    USA
    Quote Originally Posted by A K View Post
    Thanks in advance.
    Activation 2023261981724131619121 Reprogram 129811185815613
    Didn't work. Invalid password
    Nov 2012
    Thanks in advance.
    ACTIVATION 129811185815613
    REPROGRAMMING 129811185815613
    Tac Data 11292811185815613
    If I helped you press thanks or reputation button
    DK Veteran Wristpin's Avatar
    I have a problem connecting my laptop using Allison Doc ver 8 and my nexiq usb-link
    It connects to data viewer fine but when I try to connect to the transmission it connects and brings up all the information then after 2 or 3 seconds disconnects, I've tried 2 different laptops with ver 8 installed same thing. While I was there I connected to the Cat engine with my nexiq usb-link and it worked,
    Any suggestions?
    Dive Naked,
    Everything looks bigger underwater!
    Unclick auto connect and click connect-advanced setup. Then choose the exact interface and connection J1939, J1708 or J1850. With the DPA5 I have to use this method or it will kick me every time.
    Thanks alsop for the reply,
    I did try that and had the same results
    I'm not sure what's going on with this.
    I'm going to try another truck this weekend to make sure it's not the trans ecm
    Dive Naked,
    Thanks guys but I still get invalid password. I went into redgit and changed date so I have 365 days to activate.Only thing is I can't reprogram. Had 8.4 running fine and then screwed up and went to 10. That's was a nightmare so I thought I'd go back to 8.
  13. #13
    Top Poster Fool2cool's Avatar
    Dec 2010
    UK
    Hi there could I get the activation password for key: 210319210319
  14. #14
    Quote Originally Posted by Fool2cool View Post
    Pass: 16131015102510749419
  15. The Following User Says Thank You to cyph8r1975 For This Useful Post:
    Fool2cool (13th April, 2013)
  16. #15
    Jan 2013
    How can I get Verison 8.0?
