Page 2 of 32 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 476
  1. #16
    Could Yo paste a link where to buy USB-to-TTL converter based on PIC12F629 ? thanks
  2. #17
    Apr 2013
    United Kingdom
    This is very interesting, I dont mind givin a shot at making the reader. Have a few spare remote fobs to try on
  3. #18
    west mids, uk
    I would love to see this happen, you seem to be almost there, keep it up, good work here clever cloggs!!
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  4. #19
    west mids, uk
    can someone explain this to me please - peugeot/citroen remotes, as we all know cant be re used, so how is it, after virginising a bsi from scrap yard, coding to car with planet, and the original keys and remotes work fine??
    I have taken NO DATA from ori bsi, so how does this work when the pcf is locked?
    Now I am really confused
    ninja
  5. #20
    Quote Originally Posted by ninja123 View Post
    ninja
    logically its either stored else where on car, or possibly unique data from the car is being programmed into the pcf during initial programming
  6. #21
    west mids, uk
    but the key data is stored in bsi, i have used one from a scrap yard, i did FF FF in eeprom, fitted and coded - so HOW do these remotes still work???????????????????????????????
    ninja
  7. #22
    ninja
    lets say the unique data lets say vin number is programmed into the pcf during programming and the remote data is stored in the bsi and then you virginise bsi but the data is already written into the pcf with the data needed i.e. vin number etc
    or even the pcf could be locked with the unique number and thus allowing unlocking reusing the key.
  8. #23
    BG / CZ
    Here we talk about reusing the remote PCB only not along with pcf. Old pcf is useless, we must use new unlocked one and program it to car with lexia (or some other tools).
  9. #24
    Quote Originally Posted by kuti View Post
    The guy posted a schematic, but failing that if you are unable to type "usb TTL" into ebay I think this may go way above your head.
  10. #25
    west mids, uk
    I did not virginise the bsi from this car, it was from a scrap yard, so no way there was any data in bsi relating to the remote key, and the pcf is locked, so does anyone have the explanation of how this works?
    If so, then maybe we can get somewhere here, either there is a way to read the locked pcf or I am at a loss as how this procedure works ???????????????????????????????????
    And if you are refering to the vin being used to read the locked pcf, then maybe we should be looking down this route, as we can always write down vin from car in scrap yard where we steal the keys from!!
    ninja
  11. #26
    BG / CZ
    Maybe I have not explained the things good enough. I'll give another try...
    Well, first you get an old key fob, remove PCF from it and throw it to the trash. Then read data from remote (with all boring stuff with 12f629). From that data I will calculate bytes to be stored in NEW (unlocked) pcf7936. Then put this pcf into keyfob and program it in car. This is tested and working on Pug307 (remote type A5).
    BSI takes data from pcf user pages during learning sequence, this way bsi knows about remote.
  12. The Following 14 Users Say Thank You to mihotd For This Useful Post:
    armpower (2nd May, 2013), bokilee (12th June, 2015), Cesarec (15th December, 2015), Col19 (23rd June, 2021), Faraday (11th March, 2014), instakeys (18th April, 2014), kostovnikola (23rd February, 2014), MACKIE (10th August, 2013), Msmax (19th July, 2019), p1et (17th January, 2023), rayjay (12th May, 2013), Recoder (6th July, 2014), urcarpc (2nd June, 2013), zeljolaki (31st January, 2014)
  13. #27
    DK Veteran avtonega's Avatar
    EU
    ninja
    I had the same experience with C2 ( fitting used BSI) , I have successfully program used PCF & remote
    I think that the condition for program used PCF & remote is 4 digit PIN code wich you enter in BSI begining of programming?!
  14. The Following User Says Thank You to avtonega For This Useful Post:
    Col19 (15th November, 2019)
  15. #28
    ninja
    Best thing would be to sniff the data from the transponder during first programming, you would then be able to see what data is written to the pcf.
    I suppose setting the password for the pcf whether from VIN or other data from ecu etc would be the easiest way to explain how it can reuse them.
  16. #29
    west mids, uk
    Im still not convinced!! There must be something to do with the pin code, as this is the only data I used from old bsi to new bsi, I did not program the vin number, and key still programmed - so the vin number is out of the question - so I think the pin has a big part to play here, pin must be written to pcf and used to unlock it or match it?? - ill keep digging...........
    I think next time I get a car in to prog a new key, If I get enough time with it, remove bsi and read eeprom before and after.
    ninja
  17. #30
    west mids, uk
    Quote Originally Posted by mihotd View Post
    Thanks mate, I completely understand you, but im looking at this from a different view, maybe an easier way ???
    ninja
