as the difference between 0536 and 0523 remont key for PSA
The 7941 crypto for key side and remote side are connected on some,depends on how its set up. Get a cloaner from asia with logger and log the data and you will be good.The remote is based on same crypto data when its conncted. People say they do not understand why key changes, its to make cloning harder andsome keep same crypto code. Others start with a acceptable crypto code and it changes it. So its not reusable except in the car programmed into good for nothing else then on out. Half of the companies use the same and do not change. You could make a 4d cloner and a simple cloner that only does non changing crypto ie honda nissan etc. Could not do crysler.
can this be used to retrieve remote data?
KD900 Remote Maker the Best Tool for Remote Control World
If you already have this KD900 tool you can try if it gives you pure remote data (I doubt so) or can clone/read remotes without giving you any details.
Anyways it is too expensive for just getting remote data. RF reader for these remotes can be made for less than 30eur
Can You generate code for transponder for this remote:
A5AA941127AD1622EFE1
A5AA53468A9B2BC48E55
A5AAE9FAE7F86BC908E1
A5AA1F904341BB29E858
3 sequential presses, last one is long
data for pcf:
55262736
AAD9D8C9
0A55FFFF
FFFFFFFF
Is possible add data in pcf7936 with zedBull?
Yes, I think zedbull can write USER pages (last 4 rows) of PCF7936 transponder.
Hello mihotd,
Can you help me identify what cars are these remotes meant for:
- C1
- DB
The information is read with Effi - I'm looking at "User 2" middle of first two bytes.
Type C1 is Citroen C3
Type DB is Peugeot 206+ (2009-2012MY)
autoTkey (17th June, 2014)
@mihotd why not work with keydiy you could produce Peugeot/Citroen remotes for keydiy for the remotes with pcf7936 and earn from this that way
keydiy remote must support Peugeot/Citroen rolling code algo to work. Sure it is not implemented in there
