tango5 (5th February, 2019)
adapter useful for:
multiecuscan CAN programming (see ELM C19, adapter cable 3 Multiecuscan - Diagnostics software for Italian cars (Powered by FiatECUScan))
ford CAN programming with elm-config + elm-ff2 + fds (Focus2, C-MAX, Kuga, Mondeo MK4, S-MAX, Galaxy)
kkl interface k-line pin selection (iso 9141-2, kwp2000, kw1281, vag, opel, fiat...)
components less than 10euro on ebay
SAY THANKS!!
__________________
China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
always given easy and good solutions manocao !
best regards
My work is my life ART TECH GARAGE
AT commands for FORD ELM327 CAN pin selection mod
programmable parameter 2A only available from ELM327 1.3 or upper firmware version (edit: this is not true, also available for ELM327 v1.2a)
edit: updated picture
edit: AT command to show current programmable parameters: atpps
example:
>atpps
atpps
00:FF F 01:FF F 02:FF F 03:32 F means off (disabled), N means on (enabled)
04:01 F 05:FF F 06:F1 F 07:09 F
08:FF F 09:00 F 0A:0A F 0B:FF F
0C:68 F 0D:0D F 0E:FF F 0F:FF F
10:0D F 11:00 F 12:FF F 13:32 F
14:FF F 15:FF F 16:FF F 17:92 F
18:00 F 19:FF F 1A:FF F 1B:FF F
1C:FF F 1D:FF F 1E:FF F 1F:FF F
20:FF F 21:FF F 22:FF F 23:FF F
24:00 F 25:00 F 26:00 F 27:FF F
28:FF F 29:FF F 2A:38 F 2B:02 F
2C:E0 F 2D:04 F 2E:80 F 2F:0A F
to set all to defaults: atd
to disable all parameters (set them off): atppffoff
(note that these two commands don't revert programmable parameters to default values, even after reset or power off/on, you got to set them to default values by hand, see default values in the picture above)
SAY THANKS!!
__________________
Might be worth adding pin 15 to the rotary switch K to L (with a make or break) it is used quite a lot on A CLASS mercs for example instruments ect.
__________________
naser (24th March, 2013)
Pin 11 is always transmission on mercs & pin 13 on EEC5 for reprogramming, they do a 12 to 1 rotary switch so it would be ideal to keep all options open
it's ok, so then use a 1P12T rotary switch instead, we can add 4 more posibilities for k line like this:
1 -> fiat abs
3 -> fiat airbag, opel eps + immo
7 -> all engine, fiat automatic gearbox
8 -> bmw ?, fiat immo
9 -> fiat eps + climatonic
11 -> mb transmission, fiat alarm + lock doors
12 -> opel airbag + abs, fiat engine bay wiring
13 -> EEC5 reprogramming, fiat rear wiring
15 -> mb class A instruments
empty
empty
empty
please help complete pin features depending on car makes:
2 -> any make not as sae j1850+ but as k line?
6 -> any make not as can high but as k line?
10 -> any make not as sae j1850- but as k line?
14 -> any make not as can high but as k line?
this is 1p12t rotary switch
this is dpdt switch
i forgot to include a knob
__________________
Scantool.net elm327 terminal
use this to introduce AT commands for ford
__________________
Some early vauxhalls approx 1997 used pin 6 for engine ecu but not at 10400 baud , and early saab's used pin 14 without pin 6 but no idea what for
__________________
Hello, I own a 1998 Mercedes A Class, it seems to me this thread is about switches for k-lines using elm327.
The 1998 A Class w168 uses many pins for k-lines. Here's a scheme:
Pins 1, 7, 8, 11, 12, 13 and 15 are all used for klines. The cheap elm327 bluetooth adapter from china only uses pin 7 and all obd software doesn't work.
Can you suggest a solution? Switches for k-lines? I saw this post about a mod for Fiat that doesn't use switches but resistors: http://www.cardiagnostics.be/-now/Fi...ne_adapter.htm
Do you think this solution could also work for thew A Class. What about the pin 3 TNA Gasoline ? Is that used to check ignition?
don't know about mercedes pinout and protocols, i can't help, try and tell?
__________________
Hello, thanks for your reply. The protocol should be iso 9141-2, the pinouts is as in the scheme I posted.
In your scheme you put also two switches for CAN, right? I don't think I need those for MB.
I only need to access k-lines but maybe I am not getting the functionality of those switches.
Could you advise?
A class merc's use the kw2000 fast init protocol up to approx. 2004 bc ( before can )
set elm ( SP5 )
Hi, are you sure? What does 'set elm sp5' mean? Scan protocol number 5?
Anyway I see obd iso 9141-2 and kwp2000 share the same pins. The point is multiplexed k-lines and switches between them.
