may be eprom and mcu are not ok.
Hi friends, i have peugeto 406 2001 RHR bsi v2 93c66 and dashboard VDO 93c66 two connectors black and white
the problem is this, unexpectedly km set to zero and the dashboard out of service,reading the 93c66 its fill to ff!!! or data corrupt, replace with a new eeprom and it the same, help me please
on a rich or poor discussion - PL & SP blood - only on bench
eeprom was changed
I think BSI data damage , change data to the wrong address
thanks for your interest, the fail appears quickly disconnect and connect and return to normal functionally and rare oportunities the dump on dashboard crashes it, microprocessor out of control ? interferences of coil? the car 50k true, very rare!!!
Thanks friend, here you go!
I have had this on 406 was data in dash put 6 or 7 dumps in dash until i found 1 that was ok
here are 2 dumps 66 dash 4 dials
and bsi c66....
if you try the bsi dump you need to edit pin for it to start...
and the vin for the radio stop beeping..
good luck..
Metercar: What exactly do you need? Does car start? If your problem is mileage post your dumps and give original and required mileage. I have had this before and it's all to do with dash. Every bit of kit I had changed mileage in dash wrong and wrote it back to front, upside down, bytes reversed or only half, I can't remember but I remember it was dash problem not BSI.
davecooper47 the car starts and run perfectly the one problem is the dashboard and the mileage returns perfectly with reset + in the dash (black connector)
Hey memebers!! solved!!! change the coil and the dash functionaly perfect!!! thanks
what coil are you refering to...
The ignition coil pack is creating interference and impact directly on microprocessor of dashboard, Thanks VDO for your bad quality filtering!!!
sagie (13th April, 2019)
Hi! I can't find dash dump on Peugeot 406 2.0hdi, manual transmission, year 2000, 93C66 chip. Can someone help me?
