Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
    V.I.P. Member alunfennell's Avatar
    Oct 2008
    Play2Dream - Stream Movies from your PC to Dreambox
    Play2Dream
    This tool will install and configure VLC Frontend on your Dreambox,
    and configure your PC to allow you play movies from pc to Dreambox with subtitles
    Usage :
    1. Run the application c
    2. Fill all required fields : Dreambox Ip, Dreambox FTP username, Dreambox FTP password,yor favoire movies folder, your CD/DVD drive letter
    3. Press Install button
    4. Whait until application setup your dreambox
    5. The instalation of Vlc media player will begin ... press Next to install
    6. We are done, close the application
    7. With your Remote control : press green button, and select "Movies from PC"
    8. Play the movie
    This function will work on Dreambox if your PC is turned ON.
    That`s all
    Tested on Dreambox 500s & 600
  2. The Following User Says Thank You to alunfennell For This Useful Post:
    SoulM8 (13th December, 2013)
  3. #2
    Top Poster ces's Avatar
    Mar 2009
    Is this for E1 or E2?
    ces
    Top Poster ticticboom's Avatar
    May 2008
    how do i run the program on pc ? or on box?as when i click on the icon its says open with .help as this program sounds nice
    Feb 2009
    also some help needed here. i am able to record TV programmes on my PC but i am failling to play movies from my PC back to the box.
    May 2009
    Nothing happen when I presss the green button in DM remote
    Apr 2009
    get a socket error connection reset by peer :-(
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    I couldn't get streaming to work before. Installed this and problem solved Thanks Alun
    Newbie Arnather's Avatar
    Hello, When I try to install I get the message
    Socket Error # 10060
    Connection timed out.
    Any help much Appreciated
    Cheers
  10. #9
    going to try this now, hopefully its not too dificult, will it stream mkv files?
  11. #10
    I have used the program it works great only one small problem with is the audio it is to low no matter what i do with it is the samme, any suggestions please. Thnks.
  12. #11
    May 2009
    Quote Originally Posted by Arnather View Post
    Cheers
    i tried to download it but in vain. It is contaminated. It does conntain a malware and i was warned for that.
    Finally i managed to get it and i scanned it and the result was asame to harvest a real flop.
    Before leaving, this the message harvest :
    - Fichier C:\...\Desktop\Play2Dream1.4a.zip\Play2Dream1.4a\v lc\vlc-0.9.8a-win32.exe Erreur 42125 {archive ZIP corrompue.}
    - Fichier C:\...\Desktop\Play2Dream1.4a.zip\Play2Dream1.4a\P lay2Dream.exe est infect? par Win32:Trojan-gen {Other}, Supprimer: Erreur 42111 {L'op?ration n'est pas support?e pour ce type d'archive.}
  13. #12
    V.I.P. Member thered's Avatar
    Aug 2008
    thanks alun is this for enigma 1 only or any
    edit the file says its corrupt
  14. #13
    Hi!
    Your plugin use DLNA features in order to connect to PC?
    TIA!
    MoonshinerSAT
  15. #14
    Nov 2008
    France
    Great, works fine on my 7020, using Gemini 4.6 or Darkstar 2....no need to do the DVD conversion now...perhaps!
    bbfn. Andy
  16. #15
    Feb 2009
    jel ovo za E1 ili E2?
  17. The Following User Says Thank You to Igi029 For This Useful Post:
    rogayz (1st December, 2013)
