yes i also look for programmer but cannot find cheap
if some one design pcb this will be easy
hello good afternoon friend can help me how I can connect this thanks
gaznasty7 (2nd September, 2018)
hello friend could read flash and 25x80 but files are not good can someone help me thanks
25x80 dump is bad, good dump you can download from a famus thread there in the forum.
your flash dump was started welll and correct but the size is wrong and much smaller than it should be.
Any help? Nobody build this programmer?
Never built it but all the resistors must be 10 ohms, 10Kohms are too much to those signals attenuation.
carmelasse (9th August, 2013)
Already did it don't need this 10 om resistors. Works with flashkitprogrammer 2.9 async mode.
There is also need to connect +VCC to 20pin of 74ac245
Success!! Programmer build, all sectors of Fujitsu flash dumped, serial number of interface Actia/Lexia changed!! Interface work with Diagbox 7.07!!!!!!!!! (tested on C4 Picasso)
mesrine_29 (10th September, 2013), miha99 (9th August, 2013)
Ik build this simple SPIPGM programmer for programming the winbond: RayeR's homepage/Programming It works fine, but you need an old PC with parallel port. The value of the resistors could be critical. I messure the signals, all where about 3.3V, but one, the ACK(MISO) where 4.2V. I put a resistor of 8k2 from pin 2 (DO) to ground, which reduce the voltage to 3.3V.
Invalid Request
this will do
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
Hello
my question is whether or LPT programmer to work? I found a very simple scheme LPT programmer .
RayeR's homepage/Program?tor SPI FlashROM na paraleln? port
I program Winbond but nothing change ,
How did you program it and what the programmer?
