Can someone help me with the reflash procedure for PSA XS evolution and the files needed.
I need to use Diagbox above 5.29, my old laptop (windows XP) is burned and the new is windows 7.
I have UPA usb.
thanks.
"sorry about bad english"
I have UPA usb.
thanks.
Yes o can help first install Diagbox on your pc!
guilhermegti (30th March, 2013)
Hi!
thanks for reply.
I already installed diagbox 7.2 on my windows 8 64 bits laptop. The Lexia interface was proprely installed, recognised adn updated to 4.3.0 by diagbox, but i can't connect to any vehicle because my serial number is blacklisted.
I dont know to update and dont have the files for winbound eeprom and fujitsu MCU.
Can you help me with that?
Here are the drivers for lexia 3 VCI all windows 32 and 64 bits included windows 8, tested by me.
Setup Drivers DiagBox.rar
Do you have something to read winbond flash?
I have UPA usb. What device should i choose to read winbound?
There are two things to do to complete the reflashing procedures, Windbond and Fujitsu MCU.
For Windbound you can go with UPA, select EEPROM SPI M25P80 (or M25P40 depends on what is used) and set jumper to 3.3v. Read/write off circuit only and connect as SPI.
For the last needs another tool and the valid data (dump)!
gaznasty7 (2nd September, 2018), guilhermegti (3rd April, 2013), mesrine_29 (7th October, 2013), smokey08 (17th December, 2013), stefaudio (31st March, 2013), titoun (10th October, 2017)
Okay then read this and save to your pc.... In my post about interface fix is dump for winbond. Write this to your flash with upa-usb. Thats all. When you do it let me know how works
And the info seeming lost/hard to find from internet I think. Even it's the driver property but it's an effect from Fujitsu Flash.
can someone post a step by step and programs with firmware in and external download links . might and will help others
my clones seems to work fine on 7.6 but others are not
rules very good idea, I have 2 clones and do not work I can give you the solution, please help with step by step to be able to operate thanks DiagBox clone
This is the procedure to reflash fujitsu MCU and the software, no dumps needed just read edit and reflash
FlashKit29.rar
alfabug (31st July, 2013), dbj159 (11th August, 2020), djscotch (2nd April, 2013), eLKa (26th April, 2014), frigo (5th November, 2013), gaznasty7 (2nd September, 2018), hocine6325 (1st December, 2015), jnoroeste (2nd October, 2013), kleanthis sti (11th January, 2022), lolpa (26th October, 2017), mcgustoo (2nd April, 2013), micromax (2nd April, 2013), newyoga39 (16th April, 2014), Novik_UA (30th April, 2013), pedro home (31st October, 2022), pio7 (11th August, 2013), sarigol45 (27th June, 2019), velindro (28th April, 2014), vosje1 (5th November, 2014), WENKAT (29th November, 2014)
any good enough to make pcb from schematics to flash fujitsu
lolpa (26th October, 2017), nelsoncaseiro (20th January, 2020)
