Page 1 of 56 1234561151 ... LastLast
Results 1 to 15 of 836
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default Guide: Flashing a Dreambox with Dreamup
    How Do I Use Dreamup?
    If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug half way through (yes it did happen to me). This will get you back on track.
    Required
    • Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
    • Image File (.img) or a (.nfi) file
    • DreamUp Program
    Instructions
    • Disconnect all cables from your dreambox, including the power
    • Connect the null modem cable to the dreambox and to your PC
    • Load Dreamup.exe
    • Click Connect and you will see a message like this
    • Connect the power and the bootloader should be copied to the box
    • The message should now say 'Box attached and Ready'
    • Click Flash on the right hand side and select the image to be flashed
    • Click Yes or Ya (depending on the version)
    Note: If you're flashing a backup image, select NO.
    • The image should then be uploaded to the box
    • There will be a countdown timer at the bottom of the program
    • After the image is uploaded, it will be flashed to memory
    • The finished process should look like this:
    • Click OK and close down Dreamup
    • Power off the dreambox for 30 seconds then power up
    • If any errors appear, check all cables are connected properly and repeat the process but do not use the PC while it's running
    Good Luck!
  2. The Following 12 Users Say Thank You to Devilfish For This Useful Post:
    Ali71 (4th February, 2014), Boost420 (30th March, 2014), BusCan (2nd December, 2015), Chunkee262 (4th May, 2014), donnyvikings (8th November, 2013), flyndance (14th December, 2014), galacollino (5th June, 2013), happyforever (28th October, 2013), ladder 49 (9th September, 2013), ozzy30 (10th June, 2014), polly4you (18th September, 2020), seal777 (8th June, 2022)
  3. #2
    Newbie wizz240166's Avatar
    Apr 2008
    Default flash wizard pro?
    where can i get this from?
    and dd.2.0?
  4. The Following User Says Thank You to wizz240166 For This Useful Post:
    ozzy30 (16th November, 2015)
  5. #3
    thommo
    Guest
    Quote Originally Posted by wizz240166 View Post
    and dd.2.0?
    dream up in the first post and in downloads and the dw (not dd) is in the downloads aswell.
    if you have 5 posts you just have to wait for the forum to update and you will be able to get them.
  6. #4
    Apr 2008
    thanks very handy never got no instructions with my box
    Apr 2008
    Excellent instructions exactly what a novice like myself is looking for
  8. #6
    Apr 2008
    Thanks mate Im going to have a go at reflashing my Dreambox 600
  9. #7
    Top Poster jake1970's Avatar
    Apr 2008
    surrey
    many thanks i must say that you seem to explain things very well ive looked at other sites etc and found some of the guides a bit daunting ,but this is very good
    again many thanks
  10. #8
    Apr 2008
    Dublin
    Great guide - is it possible to flash using ethernet only?
  11. #9
    Member Mordor1946's Avatar
    Apr 2008
    Thumbs up Flashing Dreambox Image
    Guide looks extremely helpful but at the moment I am having trouble getting a copy of dreamup that works..thanks for info....
  12. #10
    Apr 2008
    Default null modem cable
    Where do you get this type of cable and where do you put it in the pc is it the terminal that has I0I0I0?
  13. #11
    Apr 2008
    Default Power
    When I connect power nothing happens?
    Any idea...?
  14. #12
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by glasgowkiss View Post
    Search on @bay for null modem cable, cost about ?3. and plugs into the back of your PC (you cant go wrong),
    looks like this.
  15. #13
    aftermath's Avatar
    Mar 2008
    Any idea...?
    Can you be more specific m8, no light on dreambox? or just a black screen. ?
    if its a black screen sounds like you had a bad flash, try flashing same image again sometimes that works,.
    or go through post 1 again
  16. #14
    Apr 2008
    need help again lads. i have connected a null modem cable to dreambox and pc.
    i load up dreamup and press connect. i then turn on the power but nothing happens.
    i am using com port 1 and the default local ip and remote ip. i have also tried to put in my dreambox ip address. but still nothing comes up.
    any help will be welcome.
  17. #15
    Apr 2008
    i think i got it. i got a serial lead not a null modem. what a f'ing plonker i really am.
  18. The Following User Says Thank You to animal666 For This Useful Post:
    visj (23rd February, 2014)
