Page 3 of 56 FirstFirst 123456781353 ... LastLast
Results 31 to 45 of 836
  1. #31
    May 2008
    Had a similar problem ,worked well for me.
  2. #32
    May 2008
    Dublin
    Default fake dreambox, how can i tell the differance?
    Quote Originally Posted by scurders View Post
    Excellent instructions exactly what a novice like myself is looking for
    i have a dreambox dm500-c that has 27x3 air vents , its a old one got it from the uk back in 2006 i think for nearly ?400 , back then , dont tell me " i all ready know what your thinking, im not sure what image file to download into it , because , i had a starbox fake and downloaded the wrong file into it and was a nightmare for me to get back working with no help, , anybody know the leasted and the right image file i should download for this box , thanks for your help , michael
  3. #33
    May 2008
    Netherlands
    Default DM500+
    Please be careful not to install a DM500 image on a DM500+
  4. #34
    May 2008
    Default dreambox
    how would i put a rar file into my box any help would be great trying to put nagrarom 7 but is a rar file can't get it to work in the dreamup
  5. #35
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    the rar file is a type of zip will u need to open it m8 .. download winrar its free .. u can always uninstall after http://www.win-rar.com/download.html
  6. #36
    May 2008
    Default dreambox 500-c
    hi can any one help me got dreambox 500-c and trying to put Digitalworldz Dream v2.0 onto my box using dreamup but the Digitalworldz Dream v2.0 is a rar file but not letting me put in on any help please
  7. #37
    thommo
    Guest
    Quote Originally Posted by jamiemoonie View Post
    answer is above, you dont up the rar file but the img in it.
  8. #38
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    does any one no how i put a rar file in my box it is Digitalworldz Dream v2.0 but it is a rar file how do i get it in a img to get it in my box
    You have to unrar the image, just get winrar at link below and install it, then double click on the rar file and it will open with winrar and press extract at the top and it will extract to wherever you tell it to.
    http://www.digital-kaos.co.uk/forums...hp?do=cat&id=9
  9. #39
    May 2008
    Thumbs up nice to share!
    thanks, just what i was looking for!
    brief and well done
  10. #40
    May 2008
    Very useful and a great guide.
    Also very easy to follow.
    Thanks for the info.
  11. #41
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by marvo View Post
    im trying to download latest image,,but apparently i have to post osmma firts ,,so,,here here,,
    you need to post 5 positive posts mate, pick a subject your comfortable with and post in that forum. once you got your 5 decent posts you will be ok, you might have to wait 15 mins after your 5th posts for the server to update itself.
  12. #42
    Jul 2008
    excellent this has happened to me
    <--HankyHank added 0 Minutes and 52 Seconds later...-->
    Where do i get the dream program from
    Last edited by HankyHank; 6th July, 2008 at 04:49 PM. Reason: Automerged Doublepost
  13. #43
    Jul 2008
    Hi, bit of a newbie, ive had a dreambox for a few months but i got mine pre-flashed from some1 but now it seems to need reflashing, can you tell me how often this happens or does that depends totally on the subscriber your using?
    <--E-noid added 8 Minutes and 23 Seconds later...-->
    Sorry not sure where to post this question........ :S which dreambox is rated best? there seems to be quite a few variations on the net and ive heard stories of bootlegs ones floating around that are rubbish? I have the 500c but would like one with a hdd.....or am i better off just networking the current box to my home next work and using my pc as a storage device? any help would be appreciated
    <--E-noid added 193 Minutes and 52 Seconds later...-->
    Ok no doubt loads of people have asked this before, how do you tell the difference between a null modem cable and a serial cable ? i tried a serial cable i had which i think was crossover and it didnt work.
  14. #44
    May 2008
    Default help
    any available help for use with rom 11 cards? ho to activate cardreader?
  15. #45
    Jul 2008
    Hi when using dreamup there acouple of things you need to follow i have read through the guid on how to flash the box which is detailed with very good instructions.
    the answer to the question is when using dreamup u can start by using com1 and untick use network.
    <--jkateete added 31 Minutes and 55 Seconds later...-->
    The problem is not dreamup not working i'd the same problem before and it took me some time to flash my box. the problem is the type of computer your using the com ports are disabled which was the case with my pc and i didnt have enough knowledge on how to enable them, i tried several pcs but they all didnt help me as the com ports were all disabled untill when i used my old pc with com ports not disabled. Most the of the pcs these days come disabled you need to find some one with good pc skill to enable your com ports and use a latest version of dreamup.
    Every thing should work out properly once you follow the instructions thanks.
    Last edited by jkateete; 11th July, 2008 at 10:05 PM. Reason: Automerged Doublepost
