BeeProg adapters...
Results 1 to 15 of 17
    prusony's Avatar
    Belarus
    Default BeeProg adapters...
    Hi.
    I'm looking for circuit adapters for BEEPROG programmer FLASH-1 and FLASH-4.
    Thanks for any answer.
    Alex.
    karrom's Avatar
    whate you neen
    conection pins to programmer ,you want to building adapter flash 1+flash 4
  3. The Following User Says Thank You to karrom For This Useful Post:
    prusony (7th April, 2013)
    prusony's Avatar
    Belarus
    building adapter flash 1+flash 4 - Yes, i want to building it...
    karrom's Avatar
    her you go flash 1 + flash 4 ... 56pin
  6. The Following 9 Users Say Thank You to karrom For This Useful Post:
    ADEL.KSHLAF (23rd February, 2023), gsmflasch (21st March, 2017), handmade (17th August, 2022), impuls002 (3rd June, 2013), massiwe (14th April, 2017), npepo (16th October, 2017), prusony (7th April, 2013), toms4 (31st March, 2019), Zmann (7th April, 2013)
    Sorry, are the full adapter name DIL48/TSOP56 ZIF 18.4mm Flash-1 (x16) and DIL48/TSOP56 ZIF 18.4mm Flash-4 (x16)?
  8. #6
    karrom's Avatar
    yes...full adapter name DIL48/TSOP56 ZIF 18.4mm Flash-1 and DIL48/TSOP56 ZIF 18.4mm Flash-4
  9. The Following 8 Users Say Thank You to karrom For This Useful Post:
    cubica1 (23rd March, 2017), handmade (29th July, 2022), impuls002 (3rd June, 2013), npepo (16th October, 2017), prusony (7th April, 2013), toms4 (15th April, 2019), TurboR (20th April, 2013), Zmann (7th April, 2013)
  10. #7
    prusony's Avatar
    Belarus
    2 karrom - BIG thank you!
  11. #8
    I need circuit for adapter DIL48/SSOP56 ZIF Flash-1.
  12. #9
    Member cemox's Avatar
    Kampala
    Hello
    I am looking circuite adapter 908LJ24 QFP80 to dil for Elnec programmer
    Thanks in advance
  13. #10
    tehnosoftex's Avatar
    Romania
    Thank you for the schematics. How about flash4 (x16) and flash 1(x16)? I ve tried to decode a carradio delphi rcd 510. I make several with flash 4 with no problem, but today I found one with s29gl128s instead of S29 gl128N. I try to read it like the n one but i have an error for the pin 35. i try to ignore that error and I read it. I nottice that all bytes is repeating twice. I looked on your schematics and datasheets and realise that the s one did not support 8 bits organisation, so I need a way to read it on 16 bits.
    Thank you
  14. #11
    Mar 2011
    Russia
    I need circuit for adapter DIL48/SSOP56 ZIF Flash-2
  15. #12
    Brest BY
    Hi.
    I'm looking for circuit adapters for BeeProg2 programmer
    DIL48/PQFP80 ZIF M58BW-1 (Ord. no. 70-0225)
    https://www.elnec.com/en/products/pr...0_ZIF_M58BW-1/
    DIL48/SSOP56 ZIF Flash-2 (Ord. no. 70-0099)
    https://www.elnec.com/en/products/pr...6_ZIF_Flash-2/
    Andrey.
  16. #13
    Nov 2016
    Hello, I have exactly the same problem to read S29gl128s decode a carradio delphi Skoda Bolero.
    Did you read correctly flash ?
  17. #14
    unu's Avatar
    Oct 2010
    EUROPE
    Quote Originally Posted by kowalskidebno View Post
    no one have schematic diagram for
    DIL48/TSOP56ZIF 18.4mm (x16) ????
  18. #15
    unu's Avatar
    Oct 2010
    EUROPE
    Quote Originally Posted by unu View Post
    nobody ????
