easy m8 one dash is multiplexer and the other analogic, the one wich didnt pull the km from bsi is non multiplexer, that s why the rev wont work...
Hey Folks,
I got 2 dashboads: 1 from 206 2002 with chip 95020 and second from 206 2004 with not original chip Atmel 25020.They were working before , then I changed Km on both to 100028 and then found out that I don't know the current km value in BSI, so I didn't changed in BSI. now when I plug back dashboards one is showing 162000(pulled from BSI) but the second shows 101100. we let the 101100 there for several hours(car locked, open etc) to load km from BSI, but it didn't change + RPM hand(pointer) is not working anymore. could it be that bsi shows differrent values for different year dashboards ? and could some changed Hex value in eeprom cause that RPM hand is not working anymore ? thanks for any ideas
Marian
thanks leandroks, what does it mean and how can I change then ?
it means that, the dash 2002 will work on cars till 2002, and the other dash ll work on cars from 2002 onwards
I called with friend and actually dash that didn't pull from BSI is 2004. and I wrote there that 162000 value, but for some reason it didn't pull. you got by any chance dump for 206 2004 ? and how can I differentiate between analog and multiplex ?
multiplex has only 1 white connector behind the dash
the analogic has 2 connectors ; a white AND a yellow connector
