Results 1 to 15 of 15
    Default toyota rav 4 2001 immo virgin dump
    Dear Friends,
    All keys are lost in this toyota rav 4 year 2001. The eeprom in ecu is atmel 25080. Can somebody help me with virgin dump and key ID ( 4c or 4D ) ? so that I may program a working key ? I have attached the dump from the eeprom. Many thanks in advance.
    manandhar.
    Dec 2011
    sorry cant open the file
    Top Poster + flip's Avatar
    Australia. Lowering the Gene pool
    What is the ECU part number.
    2001 = 4c
    High and Dry
  4. The Following 3 Users Say Thank You to flip For This Useful Post:
    Thamma (13th January, 2020), VictorBazan (29th August, 2015), yordan (11th October, 2016)
    key is 4c, better post key data to add in your dump
    Dear Flip,
    The ecu part no is 89661-42750. Thanks.
    Dear Flip,
    The car accepted the new key and fired. Many thanks for your help. Can you tell me how I can add another keys in this car ? I think these cars needs manual procedure to add the keys.
    Regards,
    manandhar.
    Hi mates,
    this is the key data with which the car started. key 4c: 7E C9 4F A3 90 00 00 00 00 0C 1F 7E 00 00. How can I add another key in the dump ? The next key is 4c: 7E A5 57 A3 90 00 00 00 00 34 C6 7E 00 00. Thanks for your help.
    DK Veteran key's Avatar
    Lithuania
    Hi, try this dump.
    pass in pm.
    Quote Originally Posted by manandhar View Post
    Hi mates,
  10. #9
    Hi Key,
    Thanks for your help. But the data when the car started with key 4c: 7E C9 4F A3 90 00 00 00 00 0C 1F 7E 00 00 is as I have attached here. The dump you sent didnot work.
  11. #10
    Lithuania
    you read key no tiris format, new by ok,
    password the same
    Hi Key,
  12. #11
    Dear Flip,
    Regards,
    manandhar.
    Sorry for delay, weekend.
    RAV4 security info attached
    Manual key programming and Central door locking.
    High and Dry
  13. The Following User Says Thank You to flip For This Useful Post:
  14. #12
    With virgin dump, place first key in ignition and "DO NOT CYCLE KEY" when immo light goes out place the second key in ignition "DO NOT CYCLE KEY" and wait for light to go out.
    You must pump brake pedal 5 times with in 10 seconds of last key learnt to cancel "KEY LEARN MODE".
    High and Dry
  15. The Following User Says Thank You to flip For This Useful Post:
    manandhar (20th April, 2013)
  16. #13
    Dec 2017
    Quote Originally Posted by flip View Post
    2001 = 4c
    should be fine with this. thanks
  17. #14
    May 2018
    What happen if I have a Rav4 with virgin dump intalled and use a key without transponder. Does it starts an run?
  18. #15
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by aom3000 View Post
    It will not, the only way is to immo off if you use a key without transponder.
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
