try file to locate
i have corrected the mileage but the car when driving the meter don't go up by 1 can someone correct the km for me or can someone assist me in the calculation of the algorithm. Thanks in advance.
Chip:93C66
Mileage is KM 732
it needs KM 21120
toyota camry 732.rar
that is correct 0km. But if you drive the meter will not go up. it will stay with that number.
What's Your instument Part number? 83800- ????
0000:FF 80 FF 80 FF FF FF FF FF FF FF FF FF FF FF FF
0010:FF FF FE 8F FF FF FE 8F FF FF FE 8F FF FF FF FF
0020:FF FF FF FF FF FF C3 64 C3 64 C3 64 C3 64 FE 8D
0030:FF FF C3 64 FE 8D FF FF C3 64 FE 8D FF FF D8 4F
0040:FF FE FF FF D8 4F FF FE FF FF D8 4F FF FE FF FF
0050:05 05 FF 05 C7 9F C7 9F C7 9F 1C 1B FF 1E FF FD
The Algo in Green are the mileage location. Thats what i figure out from the start.
Changing will work. But as the car drive the meter will not increase. That number will stay.
The Algo in red is when you drive the meter change, by playing with the bytes i was able to make the meter move.
but i do not have the algo calaucation completed.
If anyone can figure out the algo calacuation that would be helpful. I will continue to try. I don't got time my exam
for university is this week.
Thanks in advance ^.^
Are you sure the mileage 732 ?? need to remove needles right ?
Yes, the needle needs to be removed and yes its 732. its 2012. My mistake i put the colors wrong. it should be correct now.
Try report, if not then make swap on line 10
here is swap chnces arae 99% tetst and report
another option try to read as c86 unless you are 100% its c66
i am 100% sure its c66, thanks for the help i will official thank both of you as soon as he come back this week. As my exam are keeping me busy.
From April.
I have done a lot of this Model and yes it has a 93C66 eeprom, but you dump posted looks 7002km calculated and not 732km as you said.
I think this is a bad reading of files as I compare to my different dump the lower parts of my dumps is not the same with your dump.
lest do this remove chip from cluster and read again
Most Toyota new models needs a step down on the last few bytes, do a search it's on here in numerous places
All about the Bass
