Results 1 to 8 of 8
    Mar 2009
    Devon
    Default Oven tripping out
    Hi my Lamona 3212 built in oven trips out when ever I set it for grill or oven. Any ideas would be welcome
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    check the bulb in the interior light has not blown first.. after than i have no idea but do recommend caution...
    the Digital Kaos Disclaimer:
    Any advise offered in this forum is purely for illustration and information purposes only.. Any work carried out on electrical, mechanical or gas devices or systems whether they be at home or elsewhere must be carried out by a competent, properly certificated and qualified tradesmem from that country
  3. The Following User Says Thank You to caveman_nige For This Useful Post:
    DaveE (20th April, 2013)
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    More than likely an element has blown. For information only. As above electricity kills.
  5. The Following User Says Thank You to DOUGALMCD For This Useful Post:
  6. #4
    I had the same problem and it was the element it was causing a dead short i replaced the element and it was fine after that
  7. The Following User Says Thank You to bandit boy For This Useful Post:
  8. #5
    daithi's Avatar
    May 2009
    ireland
    what illegal substance has it been taking
  9. #6
    Meat-Head's Avatar
    Quote Originally Posted by caveman_nige View Post
    Quote Originally Posted by daithi View Post
    who we talking about here?
    ON TOPIC:-
    Yunk the oven out the dashboard or whatever you call it - YUNK the top off i guess there will be lucar connectors on the element - disconnect these and stuff some finest quality newspaper under them - then turn rcd off - turn oven to on - turn rcd on and see if it goes bing
    if it does then like monty python "Ahh i see you have amachine which goes bing"
    if if dont download new element off ebay.
    have you receently washed it?
  10. The Following User Says Thank You to Meat-Head For This Useful Post:
    DaveE (23rd April, 2013)
  11. #7
    Mar 2009
    Devon
    Thanks Meat-Head will try
  12. #8
    May 2015
    The thermostat is a wire that will be in the top left or right of the oven. If it's making contact with the metal hole that it goes through it will likely trip. You can move it but it's likely already needing replaced as you will find the damage has been caused from the tripping and it won't keep to a certain temp now
