Results 16 to 30 of 31
  1. #16
    Brayn's Avatar
    Oct 2015
    Colombo
    Passo key hole (push knob ignition) have 2 micro switches
    1. Key detection switch
    2. Push knob detection
    These both switches should be on for open steering lock and immo light goes off
    Sent from my C5502 using Tapatalk
  2. #17
    Nov 2015
    Upper switch its fine other is damage but i bridge that 2 wire and the immo light still flash
  3. #18
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by Helvio91 View Post
    When you insert key is it genarate beep sound or not??
    If beep sound comes that mean key insert detection switch good
    If switch not good
    1. Insert key and bridge that switch
  4. #19
    Nov 2015
    When i insert the key no beep at all i already bridge the switch and immo light still flash, i put easy checker on antenna and the coil is not working
  5. #20
    Brayn's Avatar
    Oct 2015
    Colombo
    What is the manufacturer year??
    Sometimes it can remove immo
  6. #21
    Nov 2015
    Its 2006 year model, ecu n-89560-b1010
  7. #22
    Brayn's Avatar
    Oct 2015
    Colombo
    You can try to remove immo
    I will send you dump file
    Write my file to engine ecu RA57
  8. #23
    Nov 2015
    Ok mate ill try, send me please
  9. #24
    Nov 2015
    Hi brayn please send me the file
  10. #25
    Brayn's Avatar
    Oct 2015
    Colombo
    Post
    write this dump to Engine ecu and try
    don't think about immo indicator
    RA56 chip engine ecu inside
  11. The Following 2 Users Say Thank You to Brayn For This Useful Post:
    kyawkyaw (9th December, 2015), taufiktechnician (16th August, 2018)
  12. #26
    Nov 2015
    ok ill do today and let u know.thanks
  13. #27
    Nov 2015
    Hi bryan cant write that file u send me got message bad file size
  14. #28
    Sep 2015
    myanmar
    Quote Originally Posted by Brayn View Post
    hello fri, can you help me passo immo off rar, please passward, thanks for very useful
  15. #29
    Sep 2015
    myanmar
    hello, all dk fri, please help me some one,toyota passo with smart key all key lost. now i need to add key , i tried but cannot add a new key please help me
    please help me passo with smart key , immo box 93lc66 and ra 57 dump file. car model year 2009
  16. #30
    Nov 2015
    Malawi
    Default immo off passo
    please help immo off toyota passo 2004 with smart key, here dump from immo box 93lc66b
  17. The Following User Says Thank You to spanaz1 For This Useful Post:
    kyawkyaw (31st March, 2016)
