dioni (31st December, 2017)
got a toyota passo with all keys lost, this is the one with smart key.
Immo or key free ecu is located behind dash, side of the steering wheel, under dash corner vent duct and tighten with two bolts on the dash reinforcement bar. Eeprom is Microchip 93lc66B. I have used tpx1 head and tmpro toyota 4c module from tmpro2. All went well, cut a key blade from driver door lock , actually I changed lock combination as security measure. Nothing need to be done on ignition lock!
Car stared straight away. Next step of course would be to get anotehr smart key and to add that in to the system...
Zedbull clone with module 105 does this also
gwee (19th April, 2013)
Dear Felix.
From what year is this car? may be that it is a 4D key smart key. please can you post a picture of the immobilizer ecu as also the file?
'll try to help.
regards
car already started!
felix17popa (19th April, 2013)
this car 4c smartkey mate post ur dump i ll send u virgin immo dump
never lost anythink only change ...
good mate ))
Hello sir i have passo with smart key i want virgin dump please
Dump from engine ecu or immo box ecu?
Ok ill post tomorrow morning thanks brayn
Brayn my passo have key and one mechanic play with steering lock and the car stop recognize the key
