You Can replace 2 glass air mass blades.
I have got Mercedes A140 been diagnosed as having a faulty air flow sensor, unfortunately the mass sir flow sensor and engine control module are both connected together.
I want to know how I programme ECU to match with transponder keys to start car, got another one from scrap yard but the car will not star.
Thanks in advance please help.
super jumbe (21st April, 2013)
Hello
here you have what you need .
Mercedes A-class air-mass (airfow) sensor
repair
Bert Rowe's-Mercedes-Benz 'A'-class info. Mass Air Flow/ECU problems and the alternative to purchasing a new unit costing ?1200.00 + Fitting from Mercedes-Benz, Special discounts available to readers of this site on guaranteed repairs.
regards
BusCan (28th January, 2014), juzzac (7th May, 2013), super jumbe (21st April, 2013)
immo is in 29f200...you can swap the flash to the scarpyard ecu...i believe is worth a try rather than all that complicated stuff.
anyway credit to these awesome poeple for finding the info
MARIKO (7th August, 2017), super jumbe (22nd April, 2013)
Stelaras26 (9th October, 2020)
just read whole the flash from the 29F200 and paste into the used
Smart car engineer ,
that too hehee didnt thought of that. And it s easy to desolder it takes 30 secs
Thanks mate I will have a go tomorrow, I will keep you posted.
Hi Mavi,
Do you need to calibrate the new sensors to the ecu? I have read some that you have to solder in a resistor to calibrate the new sensors ? or can this just be reset with Star??
Only Experimental Solution repair air flow meter A class 140.Remove original air flow meter and drill a hole in the opposite side and mount a air flow meter code 06A 906 461B four pins +12v,GND,Signal.Tested 2 cars.Adaptive Reset value.It pop out of the airflow and the engine is tested whether changes.
BusCan (27th April, 2021), giani03 (19th December, 2020), jorgelozano (22nd August, 2020), Stelaras26 (3rd January, 2023), Tzepy (25th April, 2016), yarmaa (31st August, 2016)
I have same car with same problem in garage ... if I order new glass sensors from codecard and change them, is there any other way to reset ECU beside DAS/Star? I have DAS/Star working via AVDI, but I can only diagnose cars on CAN-BUS, while this one is on old K-line.
Oh and - is there any other supplier apart from codecard for these sensors ... codecard store is closed next week.
Somebody knows something?
