good idea man, I never i checked
yugo45 (17th February, 2014)
So to get back in topic..Can someone confirm what worked for him? I am not talking about the ecuvonix solution.I am talking only about the simple hex string replacement.
What point was the correct on edc17 and what on med17 ? Which edc17 or which med17 ?PLease be specific or do not post at all because the topic gets more and more confusing.
hello to all , i think the best way to make immo off is with eeprom change solution , i have some file with this solution for med17 and i found that have the same algo , with adresse ( sometimes ) different , so if i have more file eeprom immo off with the original flash and eeprom for edc17 for vag , PSA i will found the solution from eeprom !! so please for all members how have some edc17 immo off from eeprom post te file here to get the best solution , and of course we will share it for free !!!!
Best Regards
wahye
the experience is years + years of work !
don't forget THANKS + REPUTATION
if my post was helped !
AIDIN R O (27th February, 2018), antonypaul (20th February, 2014), benzerrouki (28th March, 2014), cfgebel (20th February, 2014), chli1976 (19th February, 2014), giuseppe1374 (19th February, 2014), kowalwalcz (20th February, 2014), Meat-Head (23rd February, 2014), paskizo (26th March, 2014), radsky (19th February, 2014), smt (29th March, 2014), soxten (19th February, 2014), taxi300 (3rd January, 2015)
Hi everyone, car which I have problem:
Audi A5 2.0 TDI engine code CAHA, 125kw, gearbox manual
2010, EDC17cp14, processor Tricore SAK TC1796.
I have try adapt by AN054 Abrites Function immo parts V adaptation BCM2 without success and by immo off function. Still I can see SAFE in dashboard.
I am asking if any members with experience with Abritus AN054 and EDC17cp14 can tell me how to do immo off on this vehicle ?
Many thanks in advance.
I attached ori files and ee2_off files made by ABRITES.
You don't attached any files
Something is wrong with attachment or my PC .
It is attach now .
Unfortunately, this modification does not work still SAFE in dashboard, I also before tried this method but its not good.
Does your car runs, or start and die after 2 sec.?
Test and report.......
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
hello.
I saw this change to be made on EDC17.
but I want to know after I change to do cheksum,
you have to be to write it as it is.
when they write with Galletto asks me if I want to do chekcsum or. no
thank you very much
friend always have to correct the cks so that everything is correct, otherwise the car will not start![]()
OFF TOPIC:-
Did read about some car, for unkown reason flash get corrupt and it poured fuel down into one chamber
is there any rusk of something dimular gappening?
isht gatevut
