arvedo
I tried to help you.
I told you - send me a photo from fgtech software - maybe immo exist in OTP area.
you not sent photo
arvedo
you not sent photo
soxten
I do not know
software exist to calc cs
algo - who explain?
gttuning
upload files from ecu
regards
place ready
gttuning (30th January, 2014)
thanks i check this out!
8B022022 is repeated many times.Similar to F00FF480208B022022 only once...Which of all should be changed?
Professional BMW immo solutions
Macedonia is one and GREEK!!!
soxten (31st January, 2014)
arvedo
file to test
regards
arvedo (2nd February, 2014)
Is immo of working by changing byte?
I check on edc17c09 psa group and i did not find F00FF480208B022022.. BR.
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
I found only in bootmode read in VAG
Try to search 0F F4 80 20 8B 02 20 22
Nio (6th February, 2014)
Ok, sounds to simple to work.
I get ECUVonix next week. And hope it works on VAG.
100$ works vag
I tried it on different vehicle. Great support from team ecuvonix. I had problems checksum file PSA. They arranged for me to file for free in a few hours.
Hello svrecar and thanks for pointing out this solution.
As i see in the code after a quick dissasemble there is a not equal operation that is nullified and the return operand that you are changing.
I assume that this is he part of the code that checks if the immo code i wrong.
But i have also found out that the search string that people has to search here is the 0FF480208B022022 without the F0 infront since F0 is part of the previous routine code.Actualy it is the part of a complete memory address that stores the a vlaue(probably immo code) for comparsion in the next lines..In some case there was en E0 or 11 before the actual hex string...
For example in one case there is 19 0f 74 11 "0F F4 80 20 8B 02 20 22"
The 19 0f 74 11 is part of the same function and the code is saving the memory contents of 74 11(0x1474) to the (x)15 register
So to sume up the actual byte of the code we are searching for is "0F F4 80 20 8B 02 20 22" .In some med17 ecu versions we will find it more then once but i assume it will always be the first code that does this comparsion.
Another thing that i was thinking is if the 00 00 00 00 is not the correct way to nullify the not equal (ne) function.Is the cpu accepting those zeros correctly or we are just saved by an exception handler?
I assume that the complete code of the hex string is this
ld32.w d15, [a0]0x1474 <---- memory address that changes some times from firmware to firmware
and32 d2, d4, d15
ne d2, d2, #0 <----nullified code
ret16
GameTheoryOptimal (2nd April, 2018), Nio (6th February, 2014)
