Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Mar 2017
    Colombia
    Quote Originally Posted by lkjubaking View Post
    yep but you can read only , write impossible
    IF IT IS POSSIBLE TO WRITE .....
    it just has a different process
    WINNER THE LOSER
  2. #17
    Jan1980's Avatar
    Nov 2014
    Why everybody want to read this f...ing eprom ? Cut all wires on eprom, make a solder point on ecu plug, cut a cable and start the car... immo off fast and easy without programming..
  3. The Following 3 Users Say Thank You to Jan1980 For This Useful Post:
    cubica1 (29th October, 2017), gelencserg (20th May, 2018), Stelaras26 (30th May, 2018)
  4. #18
    Sep 2016
    This Solution also works on IAW 5nr.ce1 ECU?
  5. #19
    Oct 2015
    please pass!! THX!
  6. #20
    gelencserg's Avatar
    Garage
  7. #21
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    if its like the 5nr2 you have to cut the permanent 12v cable and solder l4 and m4 together
    But only if its like 5nr2.
  8. #22
    speedy100's Avatar
    Athens
    Hey Guys You have messed up this thread!!!
    The original post is about 5NR.T1 and You are replying about other types... like 5NR.CE... and some of You are using ..... instead of text!!!
    WTF is going on?
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
