Why everybody want to read this f...ing eprom ? Cut all wires on eprom, make a solder point on ecu plug, cut a cable and start the car... immo off fast and easy without programming..
cubica1 (29th October, 2017), gelencserg (20th May, 2018), Stelaras26 (30th May, 2018)
This Solution also works on IAW 5nr.ce1 ECU?
please pass!! THX!
if its like the 5nr2 you have to cut the permanent 12v cable and solder l4 and m4 together
But only if its like 5nr2.
Hey Guys You have messed up this thread!!!
The original post is about 5NR.T1 and You are replying about other types... like 5NR.CE... and some of You are using ..... instead of text!!!
WTF is going on?
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
