DjRomeoR (9th May, 2013)
Did car run before you did crash data erase?
I am to believe his car had same prob before crash clear, "He said" in his post somewhere that this issue was present before crash data, can clear diag so cant see this being his problem. Thats unless he took out module.
No car dont start before I erase crash.
I think my fault was what I remove airbag unit and try to reprogram on table.
I think my Airbag module are bad, to me customer can bring from other car airbag module ,ore i can what module put in my car and reset- reprogram with tech2?
Friend i dont get what you are saying? You saying car not start before you do crash data? Aswell as saying that you think its your fault as do crash on table? If car not start before you take SDM out surely it not your SDM(unless it was damaged).
If you use another SDM you either need pin to reset, or one that already reset. Or basically put your original dump with crash back on your SDM then clear via diag, think opcom maybe YOUR best option as you seem to not have function on YOUR tech2 to do much.
Car to me come after crash and she dont start.
I take off airbag module ,done crash and put file back , and after what airbag was ok.
When i connect tech2 and try reprogram immo ,but i cant do this funcion because write security code of airbag are wrong ,and i dont know how need change pin code in airbag module.
Because when i try program airbag module with tech2 ,write what :ecu are locked and program cant"
what is my story and now I asking all opinion what i can to do .
Put crash dump back in to SDM and then clear crash data using opcom. Crash data in this wont stop car from startint. I use vauxcom, so if i was you i would get cheap opcom if your tech2 dont support all function to reset all modules.
So am i correct that car spanner light is flashing?
Just reset everything like i said and car will start (should start)aslong as you put the original dump in SDM so that you can reset using your pin
DjRomeoR (14th May, 2013)
Ive had one of these corsa ds not start when no sdm plugged in car. Check eprom legs are soldered correctly on sdm curcuit board.
corsa d looks for sdm, this is why they dont start, car didnt start before he did crash data, maybe he didnt solder legs properly, but car didnt start prior to crash clear, this is why i suggest to put orignial dump in it and then reset system,common fault on these when battery goes flat that they loose sync,plus he would more than likely have eprom error fault or no comms to sdm if legs wasnt soldered properly.
thank i understan all ,but i say I DONT HAVE ORIGINAL DUMP FROM THIS AIRBAG UNIT and i cant reset airbag unit and synch... all blocks, so WHAT I can do ?
Get a SDM thats reset, get new one or just ask someone for an original dump along with pin, i cant suggest anymore apart from buy opcom aswell as your tech2 dont seem to have all function as im quite sure tech2 should have all the options and more than opcom
DjRomeoR (13th May, 2013)
Maybe you could recomendet were i can find wirgin dump with ?
On here! Put sdm number, and ask for virgin dump or just get an original and get the pin, BUT i dont know where pin is located in dump, so i would find someone that knows pin
try searching or start new thread,
I found one with crash data, same sdm number, possible pin is 2504 or if not work try 5240, but firstly try the 2504, i have never had to do this before so please bare with me on the pin . If pin goes in then just reset it and input your pin and vin, then program, then clear crash with opcom if your tech2 not do it.
Trying my best to help you, so if anyone can give some input there welcome
