Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
  1. #31
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    thank you i will try and tell you. I have now op-com ,but clone so i dont know ore work properly :/
  2. #32
    Aug 2011
    uk
    that should do job nicely mate, no worries should all be sweet now
  3. The Following User Says Thank You to flyins For This Useful Post:
    DjRomeoR (15th May, 2013)
  4. #33
    Nov 2011
    Garage...
    Thank you very much man ,car start now all ok, and airbag work good THANK YOU VERY MUCH ))))))
  5. #34
    Aug 2011
    uk
    Your welcome mate, no problem, so i guess pin for sdm was correct? 2504? And programming the way i shown you was correct? And crash cleared?
    Thank you for replying
  6. The Following User Says Thank You to flyins For This Useful Post:
    DjRomeoR (21st May, 2013)
  7. #35
    Nov 2011
    Garage...
    Yes all was like you say , Thank you .
  8. The Following User Says Thank You to DjRomeoR For This Useful Post:
    flyins (21st May, 2013)
  9. #36
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    After several attemps of bcm reset, airbag, ecu and so on,
    I've tried Flyins procedure and i've to say you a word:
    Works like a charm.
    Godd work Mate!!!
    My customer Corsa D after a dead battery have a immo (spanner) light blinking with no start condition.
    Several error in ecu about: wrong environement identifier recevied
    I've tried your procedure and the Corsa D came to life.
    Many thanks
  10. The Following User Says Thank You to armpower For This Useful Post:
    flyins (4th November, 2013)
  11. #37
    Nov 2015
    Quote Originally Posted by flyins View Post
    PIN seems ok
    Try this way, need to follow as prompted
    1reset ipc
    2 reset bcm
    3 reprogramme original key
    4 reset airbag module
    5 turned off ignition for 30 seconds
    6 programme the ipc
    7 programme the bcm
    8 programme the airbag module
    9 read and clear all fault codes
    10 ignition off 30 seconds
    11 START CAR
    If this dont work there is another way
    Thank you for this detailed answer! Very helpful!
  12. #38
    BusCan's Avatar
    Nov 2013
    PIN seems ok
    1reset ipc
    2 reset bcm
    6 programme the ipc
    7 programme the bcm
    11 START CAR
    Works well this procedure
    Thank you very much it's super nice
  13. #39
    electronistul21's Avatar
    Nov 2011
    galati,romania
    what tool use for this job?
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  14. #40
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by electronistul21 View Post
    OP-COM original for me
  15. #41
    Dunker's Avatar
    Yorkshire
    2 things with Corsa's. After resetting BCM always switch ignition off and remove key for half a minute to be on safe side. Also when programming dash you need a mint battery or charger connected. For some reason dash's don't program when voltage getting low (they do reset though - go figure).
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  16. The Following User Says Thank You to Dunker For This Useful Post:
    BusCan (12th February, 2019)
  17. #42
    Nov 2017
    POLAND
    It is possible to read pin code from airbag? I have car with swapped airbag (vin is not same) and i can't reprogram bcm by Tech2. When tech2 going to SDM i have wrong code
  18. #43
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Try 4273...
