Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Default corsa D 2007 need help
    I have a problem with Corsa 2007 year 1.2 . After crash in driver side alittle bit car haved airbag crash data storer, I cleared ,but dont start in
    car engine are this faults i tested with bosh kts 670 :
    P1632 Transponder key malfunction.
    P1678 Engine management identification faulty.
    P1679 Communication with central electronic incorrect identification received.
    When i connect to immobilizer he wrote : haves 2 programmed keys, and all values are good , but
    When i put a key and try start relays activated, but starter dont work and car doesnt start.
    I cheked fuses and all wiring everythink ok.
    What I must check now?
    P.S sorry for my english. >>> Thank you for your answers and help <<<<
    seems to be ecu not comunicating, did it got damaged, touched by impact? or loose connectors
  3. The Following User Says Thank You to ominimicu For This Useful Post:
    DjRomeoR (3rd May, 2013)
    Nov 2011
    Garage...
    Hi,no damage was deal only in driver door.
    were location impact sensor under driver seat ore how old opel in door?
    but SRS show's what all airbag units all good.
    Aug 2011
    uk
    Have you tried to reset every thing and program back in? could be possible ecu fault though
  6. The Following User Says Thank You to flyins For This Useful Post:
    DjRomeoR (4th May, 2013)
    Nov 2011
    Garage...
    yet I did not a nothing, I do not want to touch the original programs and waiting your suggestions.
    ETC... and for this model I do not have the proper equipment for block programming.
  8. #6
    Dec 2012
    Did you check to see if these faults were there before you cleared the crash data?
    To me it looks like someone's changed an ECU and it hasn't been coded in:
    If the ECU's aren't coded to each other, then the code below isn't much of a surprise.
  9. The Following User Says Thank You to RobinGill For This Useful Post:
  10. #7
    Nov 2011
    Garage...
    Yes this faults was before i cleared crash data. But Ecu vin look's same.
  11. #8
    Feb 2013
    sorry for my English
    failure seems connections
    must eliminate all accidents breakdowns
    encode and match the transponder with the ecu and bsi
  12. The Following User Says Thank You to flixuno For This Useful Post:
    DjRomeoR (6th May, 2013)
  13. #9
    Nov 2011
    Garage...
    Thanks for your answers.
    I cheked all wiring all are good,all fuses and relays are good and working.
    I can read security code from dashboard ? and this code need put in to BSI and ECU?
    Ore need special equipment for this job?
  14. #10
    Nov 2011
    Garage...
    Now i have Tech2 ,and i try to reset ECU and reprogram BCM, but then I try this funkcion, i can programm Airbag ,write what security code input are wrong, what I must to do now?
    Can I read Airbag ecu and from eeprom read a pin code?
    Please help me.
  15. #11
    Aug 2011
    uk
    read pin from dash and then swap bytes, i.e pin is just before vin, so if it read 4576 your pin is 5467 ok, plus sometimes you read the pin may be 5 digit i.e.35647 just use the last four so pin is 6574 ok, i think either you input pin wrong or bcm no good, read my posts on corsa d my friend
  16. The Following User Says Thank You to flyins For This Useful Post:
    DjRomeoR (8th May, 2013)
  17. #12
    Nov 2011
    Garage...
    Yes i read a dash eeprom , and found pin 3774 if 'am right. (I put a file if you can can you look for 100% ).
    I reset ecu ,and try reprogram BCM ,but when BCM try program SRS write what security code are wrong, maybe need input in srs good code?
  18. #13
    Nov 2011
    Garage...
    Maybe some one know in what line need to look, and need swap a bytes?
    CORSA_d_2007_dash.rar
  19. #14
    Aug 2011
    uk
    PIN seems ok
    Try this way, need to follow as prompted
    1reset ipc
    2 reset bcm
    3 reprogramme original key
    4 reset airbag module
    5 turned off ignition for 30 seconds
    6 programme the ipc
    7 programme the bcm
    8 programme the airbag module
    9 read and clear all fault codes
    10 ignition off 30 seconds
    11 START CAR
    If this dont work there is another way
  20. The Following 14 Users Say Thank You to flyins For This Useful Post:
    alaca74 (12th November, 2022), armpower (7th June, 2013), BusCan (4th December, 2023), daniersms (20th January, 2019), didi_du_93000 (21st April, 2019), Digidiagnos (15th January, 2018), DjRomeoR (8th May, 2013), indrit (30th January, 2019), jodge (14th January, 2019), klesk1986 (20th January, 2019), mitzax32 (21st May, 2018), tiguan (31st December, 2015), Tonda (6th January, 2017), wheepy (6th May, 2020)
  21. #15
    Nov 2011
    Garage...
    Thank you for your response.
    Maybe you have instruction ore can tell me how reset with tech2 ipc and airbag ecu ,because i dont find ,
    I only find how reset ECM,BCM and how need reprogram keys,transponders.... etc. but this i cant find.
    Thank your reply.
