I work with GQ4X 24lc16b choice and writing ok
Hi m8's
Got a clio III with steering fault def002 and car starts can someone help please?
trw 8200 294 976
Thanks!
test dump virgin, pass mp
FXless (7th January, 2014)
did steering angle initialization, vin and now appeared df002 again. am i doing something wrong?
I saw your test dump this one, pass such
FXless (9th January, 2014), martinracing (10th July, 2014), miki18 (14th January, 2014)
WHY DO ALL YOU KNOBS PASSWORD THESE????? DK IS A SHARING SITE, WHY UPLOAD STUFF AND PASSWORD IT, LIKE A SELF TATWTS?
LIKE YOU DON'T WANT PEOPLE TO BE HELPED, ALL IT DOES IS ANNOYS PEOPLE AND MAKES THE CUSTOMER WAIT LONGER, ALL WELL AND GOOD SAYING UPLOAD ORGINAL, BUT SOMES TIMES THERE IS NO ORGINAL, OR THE TAWT WITH THE PASSWORD EITHER FORGETS IT, DOESN'T GIVE IT OUT, OR DON'T LOG ON FOR MONTHS, BUNCH OF FRENCH C**UNTS
adam1w (21st May, 2021), albertros (2nd April, 2021), Ayoub2698 (10th June, 2020), blazej1200 (12th January, 2021), byyoyo (27th January, 2020), darrenhyland (30th April, 2014), pititec (25th August, 2016), Romcik (7th May, 2024), thurgau (19th June, 2014), zmsautogas (4th January, 2021)
you need to look at the cause of the problem. Most are can bus data error so reprograming column sorts out the fault.
The data errors often occur through the battery not upto spec. It will still start the car but if you monitored the current it falls too low for a split second causing the data in the eprom to corrupt. I always fit a new battery when I do this job. I have also had one customer come back with the fault again after replacing the battery, in this case the alternator was duff. Changed alternator - not seen him again.
This corruption of data causes D037 def1 and def2 (prob others) faults to b recorded which as we know can not be cleared because "replace column" message is also logged (bit like airbag)
But... there are times when the motor or the computor IS faulty. So clearing the dump doesn't solve the problem.
VIRTUALLY ALL THE DUMPS ON YOUR FORUM ON THE PASSWORD.
Dumps DAE match the vehicle and can not be used on another because of the immobilizer.
I also noted your last sentence I do not understand?
Translation made with google
Del66
if you have a before and after dump you can quickly help people not have dead cars around
Can someone please help me with this Clio III steernig DEF002 . Nr: 8200294976.
Please remove DF002 error or maybe virgin file...
Thank you
HI CAN ANY 1 ASSIST WITH REPAIR OF SCENIC ECU..ATTACHED IS THE 24C16 DUMP..THANKS IN ADVANCE
Hi guys
I need some help on a Modus steering . The steering column was replaced a couple of years ago , now after disconecting the batery the car doesn't starts.
I need to repair this dump or make virgin
Vin number of the car is :VF1JP0C0532909132
I have Renault Modus with steering TRW 8200433516 - fault DF002 (C1608).
Please repair the file ? I have attaced file from eeprom 24C16.
Thanks.
I repair dump but after two days I have the same problem. Please repair my dump.
